Getting Started with M5/M2Pro
- 1 Introduction
- 2 specifications
- 3 development
- 3.1 Prepare
- 3.2 Android
- 3.3 Linux
- 3.4 Other Development
- 3.4.1 Custom Linux Boot Logo
- 3.4.2 Custom Android Boot Logo
- 3.4.3 Boot Sequence
- 3.4.4 Erase EMMC for SDcard Bootup
- 3.4.5 Erase Emmc Android by dd command
- 3.4.6 Wifi/BT support
- 3.4.7 Linux Server Image Network Configuration
- 3.4.8 Disable Cloud-init&Snap
- 3.4.9 Enable rc-local
- 3.4.10 Enable sudo for Debian
- 3.4.11 Install Docker Engine
![](/images/thumb/a/a9/BPI-M2_Pro_2.jpg/300x225x300px-BPI-M2_Pro_2.jpg.pagespeed.ic.QwYAEL6-Jj.jpg)
- Mali-G31 MP2 GPU @ 650Mhz
- System Memory – 4GB LPDDR4
- Weight – 48grams
- 1. Prepare a usb-serial cable, a 5V/3A adaptor type-c power supply. The serial cable is used for console debug and type-c cable is used for android image download and ADB debug. M2pro is used Micro-usb port for android image download and ADB debug.
- or you can get the source code tar archive from Baidu Pan(pincode: 8888) or Google Drive
Android DTB overlay
- How to apply a new dtbo
- 1. ADB command via sysfs
- 3. Settings App(To-Do)
Install OpenGapps
- 2. Download device_id.apk.
- udisk:
- sdcard:
IR Remote Control Custom
- Android keycode.
- push remote.cfg back
- 3. Get the remote keycode
- custom_code = 0xfe01
- 5. Reboot the board
- 3. M5 and M2pro are compatiable with same Linux image.
- 4. Make sure bootable EMMC is formatted if you want bootup from SDcard, more info refer to Erase EMMC for SDcard Bootup
- 5. Make sure SDcard is formatted without Linux image flashed if you want bootup from EMMC and use Sdcard as storage.
- 6. Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can't access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
- 7. Download latest Linux Image, and confirm that the md5 checksum is correct.
- 8. Default login: pi/bananapi or root/bananapi
- 9. The wiki guide is only for bananapi 4.9 bsp ubuntu/debian images.
Install Image to SDcard
$ sudo balena local flash path/to/xxx-bpi-m5-xxx.img.zip $ sudo balena local flash path/to/xxx-bpi-m5-xxx.img.zip --drive /dev/disk2 $ sudo balena local flash path/to/xxx-bpi-m5-xxx.img.zip --drive /dev/disk2 --yes
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-m5-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
- 4. Install image with bpi-tools on Linux, plug SDcard to Linux PC and run
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-m5-xxx.img.zip /dev/sdX
Install Image to EMMC
- 3. There are two ways to install the linux image to board.
3.1 Install with dd command, umount mmcblk0p1 and mmcblk0p2 partition if mounted automatically. Actually bpi-copy is the same as this dd command. $ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-m5-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
3.2 Install the linux image in udisk with bpi-tools command $ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-m5-xxx.img.zip /dev/mmcblk0
- 4. After download complete, power off safely and eject the SDcard.
Build Linux Source Code
root@bananapi:~# ls /boot/overlays/ custom_ir.dtbo pwm_b-backlight.dtbo spi0.dtbo ds3231.dtbo pwm_c-beeper.dtbo uart1_cts_rts.dtbo hifi_pcm5102a.dtbo pwm_cd-c.dtbo uart1.dtbo hifi_pcm5122.dtbo pwm_cd.dtbo uart2.dtbo i2c0.dtbo pwm_ef.dtbo waveshare_tft24_lcd.dtbo i2c1.dtbo pwm_ef-f.dtbo waveshare_tft35c_lcd.dtbo pwm_ab.dtbo sdio.dtbo waveshare_tft35c_rtp.dtbo
- 2. Update the overlays env in vfat /boot/boot.ini to enable what you want. Default i2c0, spi0 and uart1 enabled.
$ sudo apt-get update $ sudo apt-get install build-essential git $ git clone https://github.com/BPI-SINOVOIP/amlogic-wiringPi $ cd amlogic-wiringPi $ chmod a+x build $ sudo ./build
$ sudo apt-get update $ sudo apt-get install build-essential python3 python3-pip python3-dev python3-setuptools git $ git clone https://github.com/Dangku/RPi.GPIO-Amlogic.git $ cd RPi.GPIO-Amlogic $ sudo python3 setup.py clean --all $ sudo python3 setup.py install
WiringPi2-Python
$ sudo apt-get update $ sudo apt-get install build-essential python3 python3-dev python3-setuptools swig git $ git clone --recursive https://github.com/Dangku/WiringPi2-Python-Amlogic.git $ cd WiringPi2-Python-Amlogic $ sudo python3 setup.py install
Luma.Examples
$ sudo apt-get update $ sudo apt-get install build-essential python3 python3-dev python3-setuptools git $ git clone https://github.com/Dangku/RPi.GPIO-Amlogic.git $ cd RPi.GPIO-Amlogic $ sudo python3 setup.py clean --all $ sudo python3 setup.py install
$ sudo python3 test/led.py
$ sudo groupadd --system xxx
$ sudo -H pip install -e .
- or
$ sudo -H pip3 install -e .
- 3. examples test
HDMI LCD
Bananapi M5/M2pro Tested HDMI LCD panel /boot/boot.ini Waveshare 3.5inch 480x320 setenv display_autodetect "false" setenv hdmimode "480x320p60hz"
Waveshare 3.5inch 640x480 Waveshare 4inch 720x720 Waveshare 5inch 960x544 Waveshare 5inch 800x480 Waveshare 5.5inch 1440x2560 setenv display_autodetect "false" setenv hdmimode "1440x2560p60hz"
Waveshare 7inch 800x480 Waveshare 7inch 1024x600 Waveshare 7.9inch 400x1280 Waveshare 8inch 1536x2048 setenv display_autodetect "false" setenv hdmimode "1536x2048p60hz"
Waveshare 8.8inch 480x1920 Waveshare 9inch 2560x1600 setenv display_autodetect "false" setenv hdmimode "2560x1600p60hz"
Waveshare 10.1inch 1024x600 Waveshare 10.1inch 1280x800 Waveshare 11.9inch 320x1480 Waveshare 12.3inch 1920x720 Waveshare 13.3inch 1920x1080 Waveshare 15.6inch 1920x1080
- backlight control
Boot Linux from USB drive
- S905x3 is not support usb boot in soc rom, so the only way for booting linux from usb drive is create a bootable sdcard or emmc with bootloader flashed, then load boot and rootfs from usb drive. After bootup, everything will run from usb drive.
- 1. The simple way is flash the M5/M2Pro Linux image to sdcard or emmc for bootable and also flash it to the usb drive for loading boot and rootfs.
- 2. Bootup the M5/M2pro board with sdcard or emmc, copy /boot/boot.ini to /boot/boot.ini.org so that bootloader load boot.ini fail and then try to load it from usb drive boot partition.
- 3. Reboot the system, bootscript and rootfs will load from usb drive.
- 4. Test performance
- You can verify the performance of your usb drive on Pi Benchmarks using the following command:
- Test results for sd, emmc and usb drive
Category Test Sdcard Test Result Emmc Test Result Usb Drive Test Result HDParm Disk Read 67.91 MB/s 156.64 MB/s 253.40 MB/s HDParm Cached Disk Read 57.39 MB/s 126.53 MB/s 253.52 MB/s DD Disk Write 13.0 MB/s 48.8 MB/s 149 MB/s FIO 4k random read 2456 IOPS (9826 KB/s) 9701 IOPS (38806 KB/s) 5474 IOPS (21897 KB/s) FIO 4k random write 938 IOPS (3753 KB/s) 12888 IOPS (51554 KB/s) 6980 IOPS (27920 KB/s) IOZone 4k read 10615 KB/s 29568 KB/s 23770 KB/s IOZone 4k write 4276 KB/s 33585 KB/s 18598 KB/s IOZone 4k random read 8661 KB/s 29637 KB/s 19982 KB/s IOZone 4k random write 4795 KB/s 38177 KB/s 22134 KB/s Score: 1300 Score: 7811 Score: 5879
- 4. Extract this tool
Boot Sequence
bananapi_m5# mmc erase 0 1000
Wifi/BT support
- 2. Linux test and support.
- How to enable Linux Wifi
- SDIO/UART type:
- Linux Wifi STA mode
- Linux Wifi AP mode
$ iw list
- 2). Install hostapd
$ sudo apt install hostapd
- 5). Start Service
- 6). Routing configuration.
- or
$ sudo apt purge cloud-init
- 2. disable or remove snap
$ sudo apt purge snapd
Enable rc-local
- Create /etc/rc.local file.
sudo nano /etc/rc.local
$ sudo chmod +x /etc/rc.local
- 1. Set up the repository
$ echo \ "deb [arch=arm64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu \ $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
- 2. Install Docker Engine
$ sudo docker run hello-world
