Banana Pi BPI-M1
Revision as of 21:07, 11 May 2018 by Sinovoip (talk | contribs) (OpenSuse)
The BPI-M1 is our first product in our goal of creating an open source devlopment board community. With a Banana Pi, we want you to explore and experience the world of DIY projects and portable computing. We welcome all companies, DIYers, and tech loving people within our community! Together, we can make a difference, we can discover our passions, inspire others, and build a practical project.
  • 1 GB DDR3 memory.
  • 1x SATA interface.
  • 1x Gigabit LAN
  • 1x USB otg and 2x USB 2.0
  • 1X MIC
  • AV vide out
  • HDMI out
  • IR
  • CSI camera interface
  • DSI display interface
  • 26 PIN gpio
Banana Pi BPI-M1
Memory 1GB DDR3
LED Power Key & 8P8C
Storage SATA 2.0,
CSI GPIO Pin Pin Name GPIO
CON1 P01 LINEINL
CON1 P02 LINEINR
CON1 P03 VCC-CSI
CON1 P04 ADC\_X1
CON1 P05 GND
CON1 P06 ADC\_X2
CON1 P07 FMINL
CON1 P08 ADC\_Y1
CON1 P09 FMINR
CON1 P10 ADC\_Y2
CON1 P11 GND
CON1 P12 CSI-FLASH PH17
CON1 P13 LRADC0
CON1 P14 TWI1-SDA PB19
CON1 P15 LRADC1
CON1 P16 TWI1-SCK PB18
CON1 P17 CSI-D0 PE4
CON1 P18 CSI0-STBY-EN PH19
CON1 P19 CSI0-D1 PE5
CON1 P20 CSI-PCLK PE0
CON1 P21 CSI-D2 PE6
CON1 P22 CSI0-PWR-EN PH16
CON1 P23 CSI-D3 PE7
CON1 P24 CSI0-MCLK PE1
CON1 P25 CSI-D4 PE8
CON1 P26 CSI0-RESET\# PH14
CON1 P27 CSI-D5 PE9
CON1 P28 CSI-VSYNC PE3
CON1 P29 CSI-D6 PE10
CON1 P30 CSI-HSYNC PE2
CON1 P31 CSI-D7 PE11
CON1 P32 CSI1-STBY-EN PH18
CON1 P33 RESET\#
CON1 P34 CSI1-RESET\# PH13
CON1 P35 CSI-IO0 PH11
CON1 P36 HPR
CON1 P37 HPL
CON1 P38 IPSOUT
CON1 P39 GND
CON1 P40 IPSOUT
LVDS GPIO of Banana pi BPI-M1
Multi 1 Multi 2
CON2 P01 IPSOUT\(5V output\)
CON2 P02 TWI3-SDA PI1
CON2 P03 IPSOUT\(5V output\)
CON2 P04 TWI3-SCK PI0
CON2 P05 GND
CON2 P06 LCD0-IO0 PH7
CON2 P07 LCDIO-03 PH12
CON2 P08 LCD0-IO1 PH8
CON2 P10 PWM0 PB2
CON2 P12 LCD0-IO2 PH9
CON2 P14 LCD0-DE PD25
CON2 P16 LCD0-VSYNC
CON2 P18 LCD0-HSYNC
CON2 P20 LCD0-CS
CON2 P22 LCD0-CLK PD24
CON2 P24 GND
CON2 P26 LCD0-D23 PD23
CON2 P28 LCD0-D22 PD22
CON2 P29 LCD0-D10 PD10
CON2 P30 LCD0-D21 PD21
CON2 P31 LCD0-D11 PD11
CON2 P32 LCD0-D20 PD20
CON2 P33 LCD0-D12 PD12
CON2 P34 LCD0-D19 PD19
CON2 P35 LCD0-D13 PD13
CON2 P36 LCD0-D18 PD18
CON2 P37 LCD0-D14 PD14
CON2 P38 LCD0-D17 PD17
CON2 P39 LCD0-D15 PD15
CON2 P40 LCD0-D16 PD16
Multi 1 Multi 2
J11 Pin1 TXD UART0-TX PB22
J11 Pin2 RXD UART0-RX PB23
Multi 1 Multi 2
J12 Pin1 5V
J12 Pin2 3.3V
J12 Pin3 NC IO-7 PH5
J12 Pin4 RXD UART7\_RX PI21
J12 Pin5 NC IO-8 PH3
J12 Pin6 TXD UART7\_TX PI20
J12 Pin7 GND
J12 Pin8 GND
All GPIO define list:
Opnewrt
  • Android 4.4 source code
Armbian image
Officeal OpenWRT
BPI BSP for OpenWRT
FreeBSD
OpenSuse
Lakka TV
Simplenas
