Banana Pi BPI-P2 Pro
Revision as of 02:54, 1 March 2023 by Sinovoip (talk | contribs) (PoE support)
Banana Pi BPI-P2 Pro is an ultra compact single board computer measures only 65mm*52.5mm. It uses 64bits quad-core Arm Cortex-A35 Rockchip RK3308 processor, with 2G RAM memory.8G eMMC flash,100M LAN,add PoE function support ,Wifi & Bluetooth onboard, It's ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
  • CPU: 64bits Quad-core Arm Cortex-A35 Rockchip RK3308.
  • 2G LPDDR2 SDRAM.
  • 8G eMMC flash onboard.
  • WiFi (AP6255) & Bluetooth onboard.
  • 100M LAN
How to development : Getting Start with BPI-P2 Pro
Memory \(SDRAM\) 2G 512M DDR3(shared with GPU) 512M DDR3(shared with GPU) 512 MB DDR2
Audio Output Mic Mini HDMI Mini HDMI Mini HDMI
IR N/A N/A N/A N/A
Weight 30g 30g 15g 9g
PoE support
we deign a IEEE 802.3af PoE module for BPI-P2 Zero ,easy to support PoE function,more spec ,please check BPI-9600 PoE module spec BPi-9600 Poe 4.jpg
