Banana Pi BPI-P2 Pro
Banana Pi BPI-P2 Pro is an ultra compact single board computer measures only 65mm*52.5mm. It uses quad-core Arm Cortex-A35 Rockchip RK3308 processor, with 2G RAM memory.8G eMMC flash,100M LAN,add PoE function support ,Wifi & Bluetooth onboard, It's ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
  • CPU:Quad-core Arm Cortex-A35 Rockchip RK3308.
  • 2G LPDDR2 SDRAM.
  • 8G eMMC flash onboard.
  • WiFi (AP6255) & Bluetooth onboard.
  • 100M LAN
How to development : Getting Start with BPI-P2 Pro
Module Banana Pi BPI-P2 Zero Banana Pi BPI-M2 ZERO Raspberry Pi Zero W
CPU Allwinner H3/H2+ Quad-core Cortex-A7 H265/HEVC 1080P Allwinner H3/H2+ Quad-core Cortex-A7 H265/HEVC 1080P Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core
IR N/A N/A N/A
Weight 30g 15g 9g
PoE support
