Banana Pi BPI-P2 Zero
Banana Pi BPI-P2 Zero is an ultra compact single board computer measures only 65mm*52.5mm. It uses quad-core Cortex A7 allwinner H3/H2+ processor(Option : H5), with 512MB RAM memory.8G eMMC flash,100M LAN,add PoE function support , It's ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
Banana Pi BPI-P2 Maker, base on BPI-P2 ZERO, without 8GB eMMC/ Wifi & Bluetooth/40PIN GPIO, all other functions are same as BPI-P2 ZERO.
- 512MB DDR 3 SDRAM.
- Mini HDMI.
- 100M LAN
- 8G eMMC flash onboard.
CPU | Allwinner H3/H2+ Quad-core Cortex-A7 H265/HEVC 1080P | Allwinner H3/H2+ Quad-core Cortex-A7 H265/HEVC 1080P | Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core |
IR | N/A | N/A | N/A |
Weight | 30g | 15g | 9g |
40 PIN GPIO of Banana pi BPI-P2 Zero | |||
CON2-P01 | VCC-3V3 | ||
CON2-P02 | VCC-5V | ||
CON2-P04 | VCC-5V | ||
CON2-P06 | GND | ||
CON2-P09 | GND | ||
CON2-P14 | GND | ||
CON2-P17 | VCC-3V3 | ||
CON2-P18 | PC4 | PC4 | |
CON2-P20 | GND | ||
CON2-P23 | SPI0-CLK | PC2 | |
CON2-P24 | SPI0-CS | PC3 | |
CON2-P25 | GND | ||
CON2-P26 | PC7 | PC7 | |
CON2-P30 | GND | ||
CON2-P34 | GND | ||
CON2-P39 | GND | ||
24 PIN CSI Camera connector of Banana pi BPI-P2 Zero | |||
CN3-P01 | NC | ||
CN3-P02 | GND | ||
CN3-P03 | CSI0-SDA | PE13 | |
CN3-P04 | CSI0-AVDD | ||
CN3-P05 | CSI0-SCK | PE12 | |
CN3-P10 | CSI0-DVDD | ||
CN3-P11 | CSI0-DOVDD | ||
CN3-P12 | CSI0-D7 | PE11 | |
CN3-P13 | CSI0-MCLK | PE1 | |
CN3-P14 | CSI0-D6 | PE10 | |
CN3-P15 | GND | ||
CN3-P16 | CSI0-D5 | PE9 | |
CN3-P17 | CSI0-PCLK | PE0 | |
CN3-P18 | CSI0-D4 | PE8 | |
CN3-P19 | CSI0-D0 | PE4 | |
CN3-P20 | CSI0-D3 | PE7 | |
CN3-P21 | CSI0-D1 | PE5 | |
CN3-P22 | CSI0-D2 | PE6 | |
CN3-P23 | GND | ||
CN3-P24 | CSI0-DOVDD |
jumper CON3 of Banana pi BPI-P2 Zero | |||
CON3 P01 | GND |
PoE support
- BPI-P2 Zero schematic diagram :https://drive.google.com/drive/folders/0B4PAo2nW2KfnflVqbjJGTFlFTTd1b1o1OUxDNk5ackVDM0RNUjBpZ0FQU19SbDk1MngzZWM?resourcekey=0-ZRCiv304nGzvq-w7lwnpjg&usp=sharing
- BPI-P2 zero CE,FCC,RoHS Certification : http://forum.banana-pi.org/t/banana-pi-bpi-p2-zero-ce-fcc-rohs-certification/9788
- BPI-P2 Zero DXF file: https://drive.google.com/file/d/1NBenPRf6Pngsio930PKuzj6IqyUK5qyr/view?usp=sharing
- magazinmehatronika BPI-P2 zero and maker review: https://www.magazinmehatronika.com/banana-pi-bpi-p2-recenzija/
- Android 4.4 source code
- Linux source code
- 2022-10-12 Armbian_22.11.0-trunk_Bananapip2zero_jammy_edge_5.19.6_xfce_desktop.img
- Google Drive:https://drive.google.com/file/d/1vP_047mfuAhSjBkZvb3w-iTGktd_BZbu/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1uhbUMYeplPybxTn_Cybpvw?pwd=8888 (pincode: 8888)
- Discuss on Forum: https://forum.banana-pi.org/t/bananapi-bpi-p2-zero-new-image-release-armbian-jammy/14026
- 2022-10-12 Armbian_22.11.0-trunk_Bananapip2zero_bullseye_edge_5.19.6_xfce_desktop.img
- Google Drive:https://drive.google.com/file/d/1YSaM1ob80EPcNoeVKYPjtCeMItBlTMET/view?usp=sharing
- Baidu Cloud:https://pan.baidu.com/s/1CrZQhN3BR6bx7uMTZYVeMQ?pwd=8888 (pincode: 8888)
- Discuss on Forum: https://forum.banana-pi.org/t/bananapi-bpi-p2-zero-new-image-release-armbian-bullseye/14025
- 2020-04-28 update, Debian 9, Rasbian Stretch, Ubuntu 16.04 Mate Desktop and Ubuntu 16.04 Server images, base on kernel 4.4,Images for m2z and p2z board are compatible.
- 2019-4-30 update BPI-M2 Zero & BPI-P2 Zero Ubuntu Server 16.04
- Image Links:
- HDMI-Version
- 2018-4-30 update BPI-M2 Zero & P2Zero Ubuntu Desktop 16.04
- Image Links:
- HDMI-Version
