Banana Pi BPI-P2 Pro
Revision as of 22:39, 28 February 2023 by Sinovoip (talk | contribs)
Banana Pi BPI-P2 Pro is an ultra compact single board computer measures only 65mm*52.5mm. It uses quad-core Cortex A7 allwinner H3/H2+ processor(Option : H5), with 2G RAM memory.8G eMMC flash,100M LAN,add PoE function support ,Wifi & Bluetooth onboard, It's ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
  • CPU: Rockchip RK3308.
  • 2G LPDDR2 SDRAM.
  • 8G eMMC flash onboard.
  • WiFi (AP6255) & Bluetooth onboard.
  • 100M LAN
How to development : Getting Start with BPI-P2 Pro
PoE support
