Banana Pi BPI-R64
Banana Pi BPI-R64 with MT7622
Banana Pi BPI-R64 Metal Case
Overview:banana Pi BPI-R64
4G with USB 4G module via USB
5G + 4G LTE+Wifi AC+Gigabit Multiplex aggregate route
BPI-R64 case
MTK MT7622
  • 1G DDR3 SDRAM
  • MTK7615 4x4ac wifi (option)
  • support 1 SATA interface
  • (1) USB 3.0
  • POE function support
Hardware Revision
SDRAM 1 GB DDR3
SATA support 1 SATA interface
USB 1 USB 3.0 host
Buttons Reset button
IR PIN define with GPIO
DC Power 12V/2A with DC in
Sizes 148 mm × 100.5mm same as Banana Pi BPI-R3 and Banana Pi BPI-R2
Weight 100g
PoE support
more PoE module spec
4G support
BPI-R64 GPIO Pin define
Amazon AWS Greengrass
Release
  • Download and setup separate ATF image for booting directly into kernel or u-boot
https://forum.banana-pi.org/t/bpi-r64-download-and-setup-separate-atf-image-for-booting-directly-into-kernel-or-u-boot/12806
OpenWRT & LEDE
  • Banana Pi BPI-R64 19.07.7 OpenWRT Router image 2021-05-01
google driver:https://drive.google.com/file/d/1YHSU8BHG-k0EcHNp0-F73Xlpiqq1ho4v/view?usp=sharing
baidu link : https://pan.baidu.com/s/1RxtvekBOxP0UtNSzx5mpEg Pincode: fthx
source code on github:https://github.com/BPI-SINOVOIP/BPI-R64-openwrt.git
discuss on forum :http://forum.banana-pi.org/t/banana-pi-bpi-r64-19-07-7-openwrt-router-image-2021-05-01/12209
  • Custom OpenWrt build for Banana Pi R64:
http://forum.banana-pi.org/t/bpi-r64-custom-openwrt-build-for-banana-pi-r64/10973
  • Mainline OpenWRT image
https://drive.google.com/drive/folders/1LQaxUAWPh6Q3QbLEIxN3JP3soIDEPzGD
discuss on forum : http://forum.banana-pi.org/t/r64-mainline-openwrt-image/11415
  • 2021-6-16 update BPI-R64 Ubuntu Server 21.04 image
Baidu link: https://pan.baidu.com/s/1nEfneNrFND1dfDLBAekdsg Pincode: dfvv
Google link : https://drive.google.com/file/d/1ieF-qTyt8LDJiaGqr0uCL4QmAxJZpjhH/view?usp=drivesdk
Fetures Map:
  • 2020-12-22 Ubuntu 18.04 with kernel 5.4.0
download link : https://download.banana-pi.dev/d/3ebbfa04265d4dddb81b/files/?p=%2FImages%2FBPI-R64%2FUbuntu18.04%2F2020-12-20-ubuntu-18.04.3-bpi-r64-5.4-sd-emmc.img.zip
supports 4G Module(EC20)
  • [BPI-R64] debian buster with new bootchain and linux 5.10,frank share this image
http://forum.banana-pi.org/t/bpi-r64-debian-buster-with-new-bootchain-and-linux-5-10/11850
Fetures Map:
AArch64 Linux
  • Image builder Arch Linux v2 with image ready for download
https://forum.banana-pi.org/t/bpi-r64-image-builder-arch-linux-v2-with-image-ready-for-download/13646
Fetures Map:
TTL Voltage
The debug-uart TTL is tolerant to 3.3V.
