| Banana Pi Single board computer Comparison
| module |
BPI-M1 |
BPI-M1+ |
BPI-M2+ |
BPI-M2 Zero |
BPI-M2 Magic |
BPI-M2 Berry |
BPI-M2 Ulra |
BPI-M3 |
BPI-M64 |
| photo |
| CPU |
A20,32 Bit Cortex™-A7 Dual-Core |
H3,32 Bit Cortex™-A7 Quad-Core |
H2+,32 Bit Cortex™-A7 Quad-Core |
A33/R16,32 Bit Cortex™-A7 Quad-Core |
R40/V40,32 Bit Cortex™-A7 Quad-Core |
A83T,32 Bit Cortex™-A7 Octa-Core |
A64, 64 Bit Cortex A53 Quad Core |
| GPU |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
PowerVR SGX544MP2 GPU |
ARM® Mali400MP2 |
| Memory \(SDRAM\) |
1G (shared with GPU) |
512M(shared with GPU) |
512(shared with GPU) |
2G (shared with GPU) |
| Onboard Storage |
SD (Max. 32GB)/MMC card slot SATA 2.0 port via SOC |
MicroSD(TF) card /MMC card slot eMMC 8GB |
MicroSD(TF) card /MMC card slot |
MicroSD(TF) card /MMC card slot eMMC 8GB(option) |
MicroSD (TF) card / MMC card slot eMMC 8GB SATA 2.0 port via USB |
MicroSD (TF) card / MMC card slot eMMC 8GB |
MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC |
MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC eMMC 8GB |
| Network |
10/100/1000 Ethernet |
NOPE |
NOPE |
| Onboard WIFI &BT |
NOPE |
802.11b/g/n |
802.11b/g/n & BT4.0 |
| Video Input |
A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps
| Video Outputs |
Supports Mini HDMI Port
| Audio Output |
Mini HDMI
| Power Source |
Micro USB with 5V/2A
| USB 2.0 Ports |
one USB 2.0 OTG
| Buttons |
Power Button, Reset Button
| Low-level peripherals |
40 Pins Header,compatible with Raspberry Pi 3
| uart GPIO\(1x3\) pin |
UART, ground
| LED |
Power led & Status led
| IR |
nope
| Supported OS |
Android, Ubuntu, Debian, Rasberry Pi Image
| Product size |
65mm × 30mm
| Weight |
35g
