Banana Pi Series Comparison
Banana Pi Single board computer Comparison | ||||||||||
module | BPI-M1 | BPI-M1+ | BPI-M2+ | BPI-M2 Zero | BPI-M2 Magic | BPI-M2 Berry | BPI-M2 Ulra | BPI-M3 | BPI-M64 | |
photo | ||||||||||
CPU | A20,32 Bit Cortex™-A7 Dual-Core | A20,32 Bit Cortex™-A7 Dual-Core | H3,32 Bit Cortex™-A7 Quad-Core | H2+,32 Bit Cortex™-A7 Quad-Core | A33/R16,32 Bit Cortex™-A7 Quad-Core | R40/V40,32 Bit Cortex™-A7 Quad-Core | R40/V40,32 Bit Cortex™-A7 Quad-Core | A83T,32 Bit Cortex™-A7 Octa-Core | A64, 64 Bit Cortex A53 Quad Core | |
GPU | ARM® Mali400MP2 | ARM® Mali400MP2 | ARM® Mali400MP2 | ARM® Mali400MP2 | ARM® Mali400MP2 | |||||
Memory \(SDRAM\) | 512M \(shared with GPU\) | |||||||||
Onboard Storage | TF card \(Max. 64GB\) | |||||||||
Onboard Network | NOPE | |||||||||
Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | |||||||||
Video Input | A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps | |||||||||
Video Outputs | Supports Mini HDMI Port | |||||||||
Audio Output | Mini HDMI | |||||||||
Power Source | Micro USB with 5V/2A | |||||||||
USB 2.0 Ports | one USB 2.0 OTG | |||||||||
Buttons | Power Button, Reset Button | |||||||||
Low-level peripherals | 40 Pins Header,compatible with Raspberry Pi 3 | |||||||||
uart GPIO\(1x3\) pin | UART, ground | |||||||||
LED | Power led & Status led | |||||||||
IR | nope | |||||||||
Supported OS | Android, Ubuntu, Debian, Rasberry Pi Image | |||||||||
Product size | 65mm × 30mm | |||||||||
Weight | 35g |
