Banana Pi BPI-M5
BPI-M5 Introduction
- Mali-G31 GPU
- 4GB LPDDR4
- 16GB eMMC flash
- 4 USB 3.0
- 1 GbE ethernet
- HDMI output
Memory | 4 GB LPDDR4 | ||
OS | Android and Linux |
SDIO interface Wifi&BT
- WiFi&BT board, 802.11 a/b/g/n/ac 2T2R WiFi and Bluetooth 5.0 , support BPI-M5 and BPI-F2P
- how to use : https://wiki.banana-pi.org/Getting_Started_with_M5/M2Pro#Wifi.2FBT_support
- RT8822CS Bluetooth and WiFi adapter for Banana Pi BPI-M5:https://www.magazinmehatronika.com/en/rt8822cs-bluetooth-and-wifi-adapter-for-banana-pi-m5/?fbclid=IwAR0Oqm4TCa2SAXBTMJgRmWMJI-VQREqFxLh1-LnT_XzA5MAvYh_BL9-L7Xk
BPI-M5 40PIN GPIO (CON2)
CON1-P01 | VCC-3V3 | ||
CON1-P02 | VCC5V | ||
CON1-P04 | VCC5V | ||
CON1-P06 | GND | ||
CON1-P09 | GND | ||
CON1-P14 | GND | ||
CON1-P15 | GPIOX_7 PWM_F | ||
CON1-P17 | VCC-3V3 | ||
CON1-P20 | GND | ||
CON1-P25 | GND | ||
CON1-P30 | GND | ||
CON1-P33 | GPIOX_6 PWM_A | ||
CON1-P34 | GND | ||
CON1-P37 | GPIOAO_9 | I2S_MCLK | |
CON1-P39 | GND | ||
BPI-M5 Debug UART(CON1)
CON2-P1 | GND |
CON2-P2 | UART0-RX |
CON2-P3 | UART0-TX |
Linux BSP source code
- BPI-M5 schematic diagram
- BPI-M5 PCB DXF file
- Amlogic S905x3 datasheet
- BANANA PI BPI-M5 REVIEW & BENCHMARKS:https://bret.dk/banana-pi-m5-review/
- BANANA PI M5 VS RASPBERRY PI 4 – BENCHMARKS : https://bret.dk/banana-pi-m5-vs-raspberry-pi-4/
- 2022-09-07 release, BPI-M2 PRO/M5-Mbox-Android9
- Baidu Cloud: https://pan.baidu.com/s/1vqFGBDzY0gdqIIkX8ap5GA?pwd=uex1 (pincode: uex1)
- Google Drive:https://drive.google.com/file/d/1qmVfN-ocQJ2WqTdFw3vk1f5_kDnRGZeM/view?usp=sharing
- MD5: ac9ac49c3b37b9cd85de65bd64f9552f
- 2022-09-07 release, BPI-M2 PRO/M5-Tablet-Android9
- Baidu Cloud: https://pan.baidu.com/s/1vrmPlyPttoKU-FkPZZE-Jg?pwd=ds7a (pincode: ds7a)
- Google Drive:https://drive.google.com/file/d/1m-b5wYWazMM_QgnQ5iQZiPRRD6AmF-Ao/view?usp=sharing
- MD5: 84d60f44761a4d4958a50e47eee7a62a
- Baidu Cloud: https://pan.baidu.com/s/1C-EiB4UcjuSYCfjFNlVL0g?pwd=8gqg (pincode: 8gqg)
- Google Drive:https://drive.google.com/file/d/1SkFY9Zoc5NY_wNXkzw514-DnN_TBy0K6/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1Z8KmmvvA8Bc-JwR4nbBOWA?pwd=dtk8 (pincode: dtk8)
- Google Drive:https://drive.google.com/file/d/1U3wLxouH2-IBBYQmHngWErLCwIJgLA7G/view?usp=sharing
Raspbian
- BPI-M5 BPI-M2 Pro new image:Raspbian image, 2022-4-09 update, Raspbian image for linux kernel 4.9 and 5.17. support 32bit and 64 bit,please choose the right image
- 2022-09-06 release Ubuntu Mate Desktop 20.04 with Kernel 4.9
- Baidu Cloud: https://pan.baidu.com/s/1XE2K_KlVwP0hvjv_AChVgg?pwd=38vx (pincode: 38vx)
- Google drive: https://drive.google.com/file/d/1OGNaEylMR-VlfY6ynRkGQNuljLcvxoqe/view?usp=sharing
- MD5: 4b0528065ddcf634e9a43b6b7a6363b1
- 2022-09-06 release, Ubuntu server 20.04 with Kernel 4.9
- Baidu Cloud: https://pan.baidu.com/s/15g52JerxZejcwywH7zZOlg?pwd=jtv5 (pincode: jtv5)
- Google drive:https://drive.google.com/file/d/15Y80CDT07HfEgo2YVjTkLSeIUGk8GQUo/view?usp=sharing
- MD5: f377dc5246f9ed7133db95c9d34b5201
- Baidu Cloud: https://pan.baidu.com/s/1IAugHTujzkTV9zfQoLw-iA?pwd=a37k (pincode: a37k)
- Google Drive:https://drive.google.com/file/d/1ASyBYkQmv6RMg_NSf2KQTpd87PosyeW-/view?usp=sharing
- 2022-09-06 release, Debian-10-buster with Kernel 4.9
- Baidu Cloud: https://pan.baidu.com/s/1BEdv5AWEYgkMcUX_ju4DPQ?pwd=2cw4 (pincode: 2cw4)
- Google Drive:https://drive.google.com/file/d/1IZ7IEFeb21ZnaAuknz9lr00jo95UX6ml/view?usp=sharing
- MD5: f6cbe3518e8a02267224a0aa0256ce11
- Baidu Cloud: https://pan.baidu.com/s/1xqk9wJ7o7aNCqa8k8Y4zGw?pwd=u5pu (pincode: u5pu)
- Google Drive:https://drive.google.com/file/d/1Ej-vYN98KZ0D17cjdtdZeDQjnkqEJ_wb/view?usp=sharing
Third part image
EmuELEC
- This is a porting of EmuELEC v4.5 for BPI-M5. I ported from odroid c4 official EmuELEC image. PS3 a XBOX ONE S gamepad controllers were tested and work fine.
- https://forum.banana-pi.org/t/emuelec-for-bpi-m5/12095
CoreELEC
- CoreELEC 19.2
Armbian Image Release on 2023-01-31
- Armbian_23.02.0-trunk_Bananapim5_jammy_current_6.1.2.img
- Baidu Cloud:https://pan.baidu.com/s/1Upd7P6rMnyEJCBZJIxSRaQ?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1u-7d07lTuodrEKZgYYA-QpJsBkOezB49?usp=share_link
- Armbian_23.02.0-trunk_Bananapim5_bullseye_current_6.1.2_minimal.img
- Baidu Cloud: https://pan.baidu.com/s/1nuIxoexLcJseUZG7tgBPXw?pwd=888 (pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/142lKwhovq5l2vYChjSI5ZT_AK0Rj9rz7?usp=share_link
- Armbian_23.02.0-trunk_Bananapim5_jammy_current_6.1.2_gnome_desktop.img
- Baidu Cloud:https://pan.baidu.com/s/1VLwACCGDcpMc3ypEG4AAOw?pwd=888(pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/133RTp3FlSjxKRKzJllcVrAoxlaYd3wyg?usp=share_link
- Armbian_23.02.0-trunk_Bananapim5_jammy_current_6.1.2_cinnamon_desktop.img
- Baidu Cloud:https://pan.baidu.com/s/1Z9H2uKtH_n0qSUSo5QnD6Q?pwd=8888(pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1GVk2D4h0vdHGUwibmSTYIYxj6WniNHhZ?usp=share_link
- Armbian_23.02.0-trunk_Bananapim5_jammy_current_6.1.2_minimal.img
- Baidu Cloud:https://pan.baidu.com/s/1ggjlqRZoOdFaOcEOpBCJmw?pwd=8888(pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1hg7gkiRsWS0oMi01Sy9XoFVDwgTJRACt?usp=share_link
- Armbian_23.02.0-trunk_Bananapim5_bullseye_current_6.1.2_xfce_desktop.img
- Baidu Cloud:https://pan.baidu.com/s/16AynRkvZZiuLq3Hjmi0BCg?pwd=8888(pincode: 8888)
- Google Drive:
- Armbian_23.02.0-trunk_Bananapim5_bullseye_current_6.1.2.img
- Baidu Cloud:https://pan.baidu.com/s/1y7qoQYKaK2DaX1VB87iweQ?pwd=8888(pincode:8888)
- Google Drive:
Volumio
- Download:
Odroid Android image
- Download:
Ubuntu Core 20
- Download:
- Baidu cloud :
Archlinux
- Download:
HuaWei OpenEuler
- Download:
Manjaro for BPI-M5
