| Banana Pi Single board computer Comparison
| module |
BPI-M1 |
BPI-M1+ |
BPI-M2+ |
BPI-M2 Zero |
BPI-M2 Magic |
BPI-M2 Berry |
BPI-M2 Ulra |
BPI-M3 |
BPI-M64 |
| photo |
| CPU |
A20,32 Bit Cortex™-A7 Dual-Core |
H3,32 Bit Cortex™-A7 Quad-Core |
H2+,32 Bit Cortex™-A7 Quad-Core |
A33/R16, 32 Bit Cortex™-A7 Quad-Core |
R40/V40, 32 Bit Cortex™-A7 Quad-Core |
| GPU |
Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0
| Memory \(SDRAM\) |
512M \(shared with GPU\)
| Onboard Storage |
TF card \(Max. 64GB\)
| Onboard Network |
NOPE
| Onboard WIFI |
SDIO AP6212(option AP6181、AP6335)
| Video Input |
A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps
| Video Outputs |
Supports Mini HDMI Port
| Audio Output |
Mini HDMI
| Power Source |
Micro USB with 5V/2A
| USB 2.0 Ports |
one USB 2.0 OTG
| Buttons |
Power Button, Reset Button
| Low-level peripherals |
40 Pins Header,compatible with Raspberry Pi 3
| uart GPIO\(1x3\) pin |
UART, ground
| LED |
Power led & Status led
| IR |
nope
| Supported OS |
Android, Ubuntu, Debian, Rasberry Pi Image
| Product size |
65mm × 30mm
| Weight |
35g
