Getting Started with M5/M2Pro
- Mali-G31 MP2 GPU @ 650Mhz
- System Memory – 4GB LPDDR4
- Weight – 48grams
- 1. Prepare a usb-serial cable, a 5V/3A adaptor type-c power supply. The serial cable is used for console debug and type-c cable is used for android image download and ADB debug. M2pro is used Micro-usb port for android image download and ADB debug.
- or you can get the source code tar archive from BaiduPan or GoogleDrive.
- BaiduPan:
- GoogleDrive:
Android DTB overlay
- How to apply a new dtbo
- 1. ADB command via sysfs
- 3. Settings App(To-Do)
Amlogic multi-dtb tool
Single dtb detected
find 2 dtbos
dtbos to be applied: 1
Apply dtbo 1
Install OpenGapps
- 2. Download device_id.apk.
- udisk:
- sdcard:
IR Remote Control Custom
- Android keycode.
- push remote.cfg back
- 3. Get the remote keycode
- custom_code = 0xfe01
- 5. Reboot the board
- 2. M5 and M2pro are compatiable with same Linux image.
- 4. Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can't access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
Install Image to SDcard
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-m5-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
- 3. Install image with bpi-tools on Linux, plug SDcard to Linux PC and run
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-m5-xxx.img.zip /dev/sdX
Install Image to EMMC
- 3. There are two ways to install the linux image to board.
3.1 Install with dd command, umount mmcblk0p1 and mmcblk0p2 partition if mounted automatically. Actually bpi-copy is the same as this dd command. $ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-m5-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
3.2 Install the linux image in udisk with bpi-tools command $ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-m5-xxx.img.zip /dev/mmcblk0
- 4. After download complete, power off safely and eject the SDcard.
Build Linux Source Code
- 2. Update the overlays env in vfat /boot/firmware/boot.ini to enable what you want. Default i2c0, spi0 and uart1 enabled.
- Build and install
$ sudo apt-get install build-essential python python-dev python-setuptools git $ git clone https://github.com/Dangku/RPi.GPIO-Amlogic.git $ cd RPi.GPIO-Amlogic $ sudo python setup.py clean --all $ sudo python setup.py build install
WiringPi2-Python
- Build and install
$ sudo apt-get install python python-dev python-setuptools swig git $ git clone --recursive https://github.com/Dangku/WiringPi2-Python-Amlogic.git $ cd WiringPi2-Python-Amlogic $ sudo python setup.py install
Boot Linux from USB drive
- S905x3 is not support usb boot in soc rom, so the only way for booting linux from usb drive is create a bootable sdcard or emmc with bootloader flashed, then load boot and rootfs from usb drive. After bootup, everything will run from usb drive.
- 1. The simple way is flash the M5/M2Pro Linux image to sdcard or emmc for bootable and also flash it to the usb drive for loading boot and rootfs.
- 2. Bootup the M5/M2pro board with sdcard or emmc, copy /boot/boot.ini to /boot/boot.ini.org so that bootloader load boot.ini fail and then try to load it from usb drive boot partition.
- 3. Reboot the system, bootscript and rootfs will load from usb drive.
- 4. Test performance
- You can verify the performance of your usb drive on Pi Benchmarks using the following command:
- Test results for sd, emmc and usb drive
Category Test Sdcard Test Result Emmc Test Result Usb Drive Test Result HDParm Disk Read 67.91 MB/s 156.64 MB/s 253.40 MB/s HDParm Cached Disk Read 57.39 MB/s 126.53 MB/s 253.52 MB/s DD Disk Write 13.0 MB/s 48.8 MB/s 149 MB/s FIO 4k random read 2456 IOPS (9826 KB/s) 9701 IOPS (38806 KB/s) 5474 IOPS (21897 KB/s) FIO 4k random write 938 IOPS (3753 KB/s) 12888 IOPS (51554 KB/s) 6980 IOPS (27920 KB/s) IOZone 4k read 10615 KB/s 29568 KB/s 23770 KB/s IOZone 4k write 4276 KB/s 33585 KB/s 18598 KB/s IOZone 4k random read 8661 KB/s 29637 KB/s 19982 KB/s IOZone 4k random write 4795 KB/s 38177 KB/s 22134 KB/s Score: 1300 Score: 7811 Score: 5879
Custom Linux Boot Logo
Custom Android Boot Logo
- 4. Extract this tool
Boot Sequence
bananapi_m5# mmc erase 0 1000
Wifi/BT support
- 2. Linux test and support.
- How to enable Linux Wifi
- SDIO/UART type:
- Linux Wifi STA mode
network:
version: 2
renderer: networkd
wifis:
wlan0:
dhcp4: true
access-points:
"bananapi":
password: "123456789"
- Linux Wifi AP mode
$ iw list
network:
version: 2
renderer: NetworkManager
wifis:
wlan0:
dhcp4: no
access-points:
"bananapi":
mode: ap
band: 2.4GHz
channel: 6
auth:
key-management: psk
network:
version: 2
wifis:
wlan0:
dhcp4: no
access-points:
"bananapi":
mode: ap
band: 5GHz
channel: 36
auth:
key-management: psk
network:
version: 2
renderer: networkd
ethernets:
wlan0:
dhcp4: no
addresses:
- 192.168.11.1/24
- 2). Install hostapd
$ sudo apt install hostapd
option routers 192.168.11.1;
- 5). Start Service
- 6). Routing configuration.
Cloud-init&Snap
- or
$ sudo apt purge cloud-init
- 2. disable or remove snap
$ sudo apt purge snapd
Enable rc-local
- Create /etc/rc.local file.
sudo nano /etc/rc.local
$ sudo chmod +x /etc/rc.local
Enable sudo for Debian
$ su - Password:(enter bananapi) # apt install sudo # adduser pi sudo
Install Docker Engine
- 1. Set up the repository
$ echo \
- 2. Install Docker Engine
$ sudo docker run hello-world
