Banana Pi Series Comparison
Revision as of 02:20, 12 May 2018 by Sinovoip (talk | contribs)
Banana Pi Single board computer Comparison
module BPI-M1 BPI-M1+ BPI-M2+ BPI-M2 Magic BPI-M2 Berry BPI-M2 Ulra BPI-M3 BPI-M64 BPI-M3
CPU H2+ Quad-core Cortex-A7 H265/HEVC 1080P
GPU Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0
Memory \(SDRAM\) 512M \(shared with GPU\)
Onboard Storage TF card \(Max. 64GB\)
Onboard Network NOPE
Onboard WIFI SDIO AP6212(option AP6181、AP6335)
Video Input A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps
Video Outputs Supports Mini HDMI Port
Audio Output Mini HDMI
Power Source Micro USB with 5V/2A
USB 2.0 Ports one USB 2.0 OTG
Buttons Power Button, Reset Button
Low-level peripherals 40 Pins Header,compatible with Raspberry Pi 3
LED Power led & Status led
IR nope
Supported OS Android, Ubuntu, Debian, Rasberry Pi Image
Product size 65mm × 30mm
Weight 35g
