Banana Pi Single board computer Comparison
module |
BPI-M1 |
BPI-M1+ |
BPI-M2+ |
BPI-M2 Magic |
BPI-M2 Berry |
BPI-M2 Ulra |
BPI-M3 |
BPI-M64 |
BPI-M3
photo |
CPU |
H2+ Quad-core Cortex-A7 H265/HEVC 1080P
GPU |
Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0
Memory \(SDRAM\) |
512M \(shared with GPU\)
Onboard Storage |
TF card \(Max. 64GB\)
Onboard Network |
NOPE
Onboard WIFI |
SDIO AP6212(option AP6181、AP6335)
Video Input |
A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps
Video Outputs |
Supports Mini HDMI Port
Audio Output |
Mini HDMI
Power Source |
Micro USB with 5V/2A
USB 2.0 Ports |
one USB 2.0 OTG
Buttons |
Power Button, Reset Button
Low-level peripherals |
40 Pins Header,compatible with Raspberry Pi 3
uart GPIO\(1x3\) pin |
UART, ground
LED |
Power led & Status led
IR |
nope
Supported OS |
Android, Ubuntu, Debian, Rasberry Pi Image
Product size |
65mm × 30mm
Weight |
35g
