Getting Started with CM4
- 1 Introduction
- 2 development
- 2.1 Prepare
- 2.2 Android
- 2.3 Linux
- 2.3.1 Prepare
- 2.3.2 Install Image to SDcard
- 2.3.3 Install Image to EMMC
- 2.3.4 Build Linux Source Code
- 2.3.5 DTB overlay
- 2.3.6 Enable Camera
- 2.3.7 Switch Mipi Panel
- 2.3.8 Panel Rotation
- 2.3.9 WiringPi
- 2.3.10 RPi.GPIO
- 2.3.11 WiringPi2-Python
- 2.3.12 Custom Linux Boot Logo
- 2.3.13 EC20 LTE 4G Module
- 2.3.14 Boot Linux from SSD
- 2.4 Other Development
- 2. Short the usb boot test point on the main board, plugin type-c usb cable to PC or press the RST button if power adapter already connected, about two seconds later, the board will enter usb download mode and be identified correctly by PC. You can also enter usb download mode with adb command "adb reboot update" or console command "reboot update" if a bootable android already flashed, make sure typec usb connected to PC before doing this.
Android DTB overlay
- Bananapi CM4 DTBO idx value table, default idx value is 0 in release image.
Bananapi CM4 DTBO idx value table idx value device tree overlay description 0 android_p_overlay default dtbo, no use 1 wifi_bt_rtl8822cs enable bpi rtl8822cs wifi/bt module 2 i2c1 enable i2c 1 3 i2c2 enable i2c 2 4 sdio enable sdio 5 uart1 enable 2 pins uart 1 6 uart1_cts_rts enable 4 pins uart 1 7 uart2 enable 2 pins uart 2 8 hifi_pcm5122 enable i2s pcm5122 HiFi DAC
- How to apply a new dtbo
- 1. ADB command via sysfs
- 3. Settings App(To-Do)
Install OpenGapps
- 2. Download device_id.apk.
- udisk:
- sdcard:
Switch Mipi Panel
Panel Rotation
diff --git a/device/bananapi/bananapi_m2s/bananapi_m2s.mk b/device/bananapi/bananapi_m2s/bananapi_m2s.mk index 1f51703..d592a44 100644 --- a/device/bananapi/bananapi_m2s/bananapi_m2s.mk +++ b/device/bananapi/bananapi_m2s/bananapi_m2s.mk @@ -579,6 +579,6 @@ PRODUCT_PROPERTY_OVERRIDES += \ else PRODUCT_PROPERTY_OVERRIDES += \ ro.sf.lcd_density=213 \ - ro.sf.primary_display_orientation=0 + ro.sf.primary_display_orientation=90 endif
diff --git a/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts b/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts index 4a698b0..3d41b63 100755 --- a/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts +++ b/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts @@ -876,8 +876,8 @@ reg = <0x5d>; reset-gpio = <&gpio GPIOA_6 GPIO_ACTIVE_HIGH>; irq-gpio = <&gpio GPIOA_5 GPIO_ACTIVE_HIGH>; - rotation = <4>; /* sf_rotation 0 */ - //rotation = <0>; /* sf_rotation 90*/ + //rotation = <4>; /* sf_rotation 0 */ + rotation = <0>; /* sf_rotation 90*/ //rotation = <5>; /* sf_rotation 180 */ //rotation = <3>; /* sf_rotation 270 */
Custom Android Boot Logo
- 4. Extract this tool
- 4. Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can't access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-cm4-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
- 3. Install the linux image in udisk with bpi-tools on Linux, plug SDcard to Linux PC and run
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-cm4-xxx.img.zip /dev/sdX
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-cm4-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-cm4-xxx.img.zip /dev/mmcblk0
root@bananapi:~# ls /boot/overlays/ hifi_pcm5122.dtbo pdmmic.dtbo sdio.dtbo waveshare_tft24_lcd.dtbo i2c1.dtbo pwm_c-beeper.dtbo spi0.dtbo waveshare_tft35c_lcd.dtbo i2c2.dtbo pwm_cd-c.dtbo spi0_flash.dtbo wifi_bt_rtl8822cs.dtbo i2s.dtbo pwm_cd.dtbo uart1_cts_rts.dtbo i2smic.dtbo pwm_ef.dtbo uart1.dtbo os08a10.dtbo pwm_ef-f.dtbo uart2.dtbo
Enable Camera
overlays="os08a10"
Switch Mipi Panel
Panel Rotation
Section "Device" Identifier "Configured Video Device" # Rotate off # Option "Rotate" "off" # Rotate Right / clockwise, 90 degrees Option "Rotate" "CW" # Rotate upside down, 180 degrees # Option "Rotate" "UD" # Rotate counter clockwise, 270 degrees # Option "Rotate" "CCW" EndSection Section "InputClass" Identifier "Coordinate Transformation Matrix" MatchIsTouchscreen "on" MatchProduct "goodix-ts" MatchDevicePath "/dev/input/event0" MatchDriver "libinput" # Rotate Right / clockwise, 90 degrees Option "CalibrationMatrix" "0 1 0 -1 0 1 0 0 1" # Rotate upside down, 180 degrees # Option "CalibrationMatrix" "-1 0 1 0 -1 1 0 0 1" # otate counter clockwise, 270 degrees # Option "CalibrationMatrix" "0 -1 1 1 0 0 0 0 1" EndSection
- Note: This WiringPi only support set 26pin gpio to output, input, pwm or software pwm, for io functions as i2c, spi, ..., you must enable dtb overlay in boot.ini
- lcd1602-pi, BPI LCD 1602 display module example.
- Build and install
WiringPi2-Python
- Build and install
$ sudo apt-get Install python python-dev python-setuptools swig git $ git clone --recursive https://github.com/Dangku/WiringPi2-Python-Amlogic.git $ cd WiringPi2-Python-Amlogic $ sudo python setup.py install
EC20 LTE 4G Module
- 1. AT test
- After the module is connected and Linux OS bootup. several ttyUSB* device files are created in the directory /dev. For EC20, /dev/ttyUSB2 is the AT port.
- 2. Connect Network via qmi_wwan on Ubuntu Desktop
- Choose qmi channel device
- When the qmi_wwan_q driver has been installed in the module, a network device and a QMI channel are created. The network device is named as wwanX and the QMI channel is /dev/cdc-wdmX. The network device is used for data transmission, and QMI channel is used for QMI message interaction
- Choose carrier provider.
- Set connection name, carrier connection username/password and APN if needed.
- 3. Connect Network via pppd on Ubuntu&Debian Server
- Install pppd
$ sudo apt install ipppd
- Two ways command to start pppd, you can check the process of PPP calling setup log here.
# pppd call quectel-ppp &
- or
- Terminate pppd process:
# quectel-ppp-kill
- 4. Connect Network via qmi_wwan on Ubuntu&Debian Server
- [quectel-CM] is a connection manager program for you to set up data connection manually. You can check the process of qmi_wwan calling setup log here.
# quectel-CM &
- Terminate quectel-CM process:
# killall quectel-CM
Boot Linux from SSD
- A311d soc rom and BPI-M2S-bsp uboot are both not support nvme boot, so the only way for booting linux from SSD is create a bootable sdcard or emmc with bootloader and boot partition flashed, then load rootfs from SSD. After bootup, everything will run from SSD. You need a minipcie to nvme adapter board because bananapi cm4io has a minipcie slot onboard.
- 1. The simple way is flash the CM4 Linux image to sdcard or emmc for bootable and also flash it to the nvme ssd for loading rootfs.
- 2. Bootup the CM4 board with sdcard or emmc, modify /boot/boot.ini to load rootfs from nvme partition for kernel.
diff a/boot/boot.ini b/boot/boot.ini index 2222e79..c485067 100755 --- a/boot/boot.ini +++ b/boot/boot.ini @@ -20,6 +20,8 @@ fi; if test "${devtype}" = "usb"; then setenv rootfsdev "/dev/sda2"; fi +# force set root=/dev/nvme0n1p2 +setenv rootfsdev "/dev/nvme0n1p2" + # Load env.txt fatload ${devtype} ${devno}:1 ${env_loadaddr} env.txt env import -t ${env_loadaddr} ${filesize};
- 4. Test performance
- You can verify the performance of your SSD on Pi Benchmarks using the following command:
- Test results for sd, emmc and nvme ssd (Samsung 970EVOPlus)
Category Test Sdcard Test Result Emmc Test Result Nvme SSD Test Result HDParm Disk Read 60.67 MB/s 148.80 MB/s 351.29 MB/s HDParm Cached Disk Read 56.71 MB/s 141.02 MB/s 347.03 MB/s DD Disk Write 14 MB/s 51.0 MB/s 244 MB/s FIO 4k random read 2176 IOPS (8704 KB/s) 8438 IOPS (33753 KB/s) 101386 IOPS (405544 KB/s) FIO 4k random write 932 IOPS (3729 KB/s) 10876 IOPS (43505 KB/s) 43206 IOPS (172827 KB/s) IOZone 4k read 8586 KB/s 20311 KB/s 119475 KB/s IOZone 4k write 2385 KB/s 19016 KB/s 90619 KB/s IOZone 4k random read 6734 KB/s 20807 KB/s 51517 KB/s IOZone 4k random write 3737 KB/s 22731 KB/s 95139 KB/s Score: 1076 Score: 5446 Score: 24550
Boot Sequence
Cloud-init&Snap
- or
$ sudo apt purge cloud-init
- 2. disable or remove snap
$ sudo apt purge snapd
Enable rc-local
- Create /etc/rc.local file.
sudo nano /etc/rc.local
$ sudo chmod +x /etc/rc.local
Enable sudo for Debian
$ su - Password:(enter bananapi) # apt install sudo # adduser pi sudo
Install Docker Engine
- 1. Set up the repository
$ echo \ "deb [arch=arm64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu \ $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
- 2. Install Docker Engine
$ sudo docker run hello-world
