Getting Started with BPI-R3
Revision as of 02:52, 4 January 2023 by Czj (talk | contribs) (→SFP)
  • . Wifi 6/6E 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P)
  • . 2G DDR RAM
  • . 8G eMMC flash
  • . 2 SFP 2.5GbE
  • . 5 GbE network port
  • . POE support (optional)
  • . Mini PCIe via USB
  • . M.2 KEY-E PCIe inerface
  • . Mciro SD card interface
  • . 26 PIN GPIO
 * Using your USB-Serial Connect debug console on BPI-R3
 * R3 bootstrap and device select Jumper Setting
  Note: SW1-A and SW1-B is for boot strap selecting;
        SW1-C is that SPI-Nand or SPI-Nor Device is connected to CPU's SPI bus;
        SW1-D is that SD Card or EMMC device is connected tp CPU's EMMC bus.
  * Examples:
    All Jumper is High.
    All Jumper is Low.
How to burn image to SD card
   * apt-get install pv
   4.After step 3, then you can insert your TF card into R3, and press power button to setup R3
   1. Download the tools from the website:   https://sourceforge.net/projects/win32diskimager/
   3. flash image into SD card.
 Note: because SD card and EMMC device share one SOC's interface, you need flash one SD image firstly, then R3 boot from SD card, then flash nand image into Nand, then change boot strap to boot from nand,  you need flash EMMC image into EMMC. Finally you change bootstrap to boot from EMMC.
    * mtd erase /dev/mtd0
Network-Configuration
root@OpenWrt:/# ifconfig
         collisions:0 txqueuelen:1000
         Interrupt:124
         Interrupt:124
lo Link encap:Local Loopback
         Interrupt:6
root@OpenWrt:/#
GPIO
26 Pins Definition
  • echo 433(22+411) > /sys/class/gpio/export
  • echo out > /sys/class/gpio/gpio433/direction
  • echo 1 > /sys/class/gpio/gpio433/value
PWM FAN Control
  • echo 0 > /sys/class/pwm/pwmchip0/export
  • echo 10000 > /sys/class/pwm/pwmchip0/pwm0/period
  • echo 5000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
  • echo normal > /sys/class/pwm/pwmchip0/pwm0/polarity
  • echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable
miniPCIe slot
SFP
After high and low temperature test, the following modules are suppoted by BPI-R3:
4G&5G
  • BPI-R3 supports 4G LTE EC25.
  • If you want to use 5G on BPI-R3:
Note: The availability of 4G/5G depends on the local carrier spectrum.
Ap mode on BPI-R3
  • ra0 is MT7986a 2.4G wifi
  • rax0 is MT7986a 5G wifi
Wifi & Serial cable
  • If the chip type of serial cable is pl2303, the driver fails to load the firmware apparently and thus the wifi can't work.
  • Other types including cp2102,ch340 and FDTI are all available.
  • MT7986a Reference Manual for Develope Board(BPi)
Google Drive:https://drive.google.com/file/d/1biSJmxnIpNzQroYDg9mtPtSTAv4i0DFf/view?usp=sharing
Reference Link
http://forum.banana-pi.org/
