Banana Pi BPI-R3
Revision as of 19:38, 27 December 2022 by Sinovoip (talk | contribs) (Application direction)
Banana Pi BPI-R3 with PoE function support
Banana Pi BPI-R3 Router board with MediaTek MT7986(Filogic 830) quad core ARM A53 + MT7531A chip design ,2G DDR RAM ,8G eMMC flash onboard,It is a very high performance open source router development board,support Wi-Fi6 2.4G wifi use MT7975N and 5G wifi use MT7975P, support 2 SFP 2.5GbE port, and 5 GbE network port.
  • . Internet service Router
  • . Wireless Router
  • . Wireless Repeater
  • . Home security Gateway
  • . Home Automation
  • . Nas device
  • . Network and communication applications
  • . Wifi 6 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P)
  • . 2G DDR RAM
  • . 8G eMMC flash
  • . 2 SFP 2.5GbE
  • . 5 GbE network port
  • . POE support (optional)
  • . Mini PCIe via USB
  • . M.2 KEY-E PCIe inerface
  • . Mciro SD card interfact
  • . 26 PIN GPIO
Jumper setting
Jumper Setting of Banana pi BPI-R3
Jumper Setting SW1 SW2 SW5 SW6
SPIM-NoR Low Low Low X
SPIM-Nand High Low High X
eMMC Low High High Low
SD card High High X High
HardWare Specification of Banana pi BPI-R3
CPU MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53+MT7531 chip design
SDRAM 2 GB DDR4
GPIO 26 Pin GPIO,some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
On board Network 5 Port 10/100/1000Mbps Ethernet
SFP 2 SFP 2.5GbE
Wifi Wifi 6 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P)
mini PCIE Mini PCIe via USB
M.2 interface M.2 KEY-M PCIe inerface
USB 1 USB 3.0 host ,2 USB interface with slot.
Buttons Reset button,WPS botton, boot switch
DC Power 12V/2A with DC in
Sizes 100.5x148mm same as Banana Pi BPI-R64 and Banana Pi BPI-R2
Weight 200g
Notes:
Baidu link: https://pan.baidu.com/s/1JSQ7wJTCeK4JqWR_XB-LLQ?pwd=6vdb (Pincode: 6vdb)
Google link:https://drive.google.com/file/d/13nQMfM0_XTyWcILhNxv_9E4TIvb65RI0/view?usp=sharing
Release image
  • 2022-06-01udptae BPI-R3 OpenWRT 21.02 linux kernel 5.4, wifi 6 2.4G and 5G working fine support nand flash ,SD card ,eMMC flash boot. for BPI-R3 production version hardware
Google drive :https://drive.google.com/file/d/18_xst-diDdCg7CeSum1M5FDbbo31jFJq/view?usp=drivesdk
Baidu link: https://pan.baidu.com/s/1idqU1-bB4XD1LTGDAJxRGA?pwd=chez Pincode: chez
Discuss on forum : https://forum.banana-pi.org/t/banana-pi-bpi-r3-openwrt-image/13236
  • 2022-09-28 udptae BPI-R3 OpenWRT 21.02 linux kernel 5.4, wifi 6 2.4G and 5G working fine support nand flash ,SD card ,eMMC flash boot, support EC25 LTE 4G
Google drive: https://drive.google.com/file/d/1oNcnIl8bDla9pPWUd-TFPXXphsCMsJt0/view?usp=sharing
Baidu link: https://pan.baidu.com/s/1v4sKfAuax3AfHNtp_2RP_g?pwd=mebq (Pincode: mebq)
  • [BPI-R3] Debian Bullseye Image, this image is share by Frank:
https://forum.banana-pi.org/t/bpi-r3-debian-bullseye-image/14541
  • 2022-12-18-debian-11-bullseye-lite-bpi-r3-5.15-sd-emmc.img, Kernel 5.15.77
Baidu Cloud: https://pan.baidu.com/s/195HeMXjK-rmCEZTnYBCndA?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/file/d/1NRR1hKsv6vE1bHOyRjcCGiHgmgaRxt72/view?usp=share_link
  • 2022-12-18-debian-10-buster-lite-bpi-r3-5.15-sd-emmc.img, Kernel 5.15.77
Baidu Cloud: https://pan.baidu.com/s/1_OGb8ZMF4pWIbaKJ0z2JsA?pwd=8888 (pincode: 8888)
Google Drive: https://drive.google.com/file/d/1Q9ZSCZ8_ZI6o5SG4_iOn-mQUaci6Qfrt/view?usp=share_link
  • 2022-12-18-ubuntu-22.04-server-bpi-r3-aarch64-sd-emmc.img
Baidu Cloud: https://pan.baidu.com/s/1PajBEeFkgzgBdmJa5KpHpA?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/file/d/1m9TFmnICj45b61evvmz9ja0g7kH641SG/view?usp=share_link
