BPI-Bit-S2
[hide]About BPI-Bit-S2
BPI-Bit-S2 development board is a successor to BPI:Bit, inheriting most of the core hardware functions.
key features
- ESP32-S2
- 5x5 RGB LED matrix
- 1 buzzer
- 1 thermistor sensor
- 2 photosensitive sensors
- 2 buttons on the front, 1 reset button and 1 boot button on the back
- Type-C USB interface
- Size 5x5cm
- The Goldfinger Edge Connector definition is fully compatible with Micro: Bit
Hardware upgrade and function comparison
BPI:Bit VS BPI-Bit-S2 | ||
Module | BPI:Bit | BPI-Bit-S2 |
SoC control chip | ESP32 | ESP32-S2 |
ROM | 448 KB | 128 KB |
RAM | 520 KB | 320 KB |
FlASH ROM | 4096 KB | 4096 KB |
PSRAM | None | 2048 KB |
Wireless Capability | WIFI,Bluetooth | WIFI |
all-color LED | 25 WS2812-5050 Lamp beads | 25 WS2812-3535 Lamp beads |
Key | 2 programmable keys,1 RST key | 2 programmable keys,1 BOOT key,1 RST key |
buzzer | 5.3x5.3mm buzzer | 8.5x8.5mm buzzer |
USB interface | Micro USB | Type-C USB |
USB to TTL | support | None |
battery interface | support | None |
IO | 19 pin Goldfinger IO | 19 pin Goldfinger IO |
Nine-axis sensor | support | None |
photosensitive sensor | 2 | 2 |
thermistor sensor | 1 | 1 |
BPI-Bit-S2 specification | |
SoC | ESP32-S2FN4R2,Xtensa® 32 bit LX7 Single-Core Processer |
frequency | 240MHz MAX |
operating temperature | -40℃~+85℃ |
ROM | 128 KB |
SRAM | 320 KB |
FLASH ROM | 4 MB |
PSRAM | 2 MB |
WIFI | IEEE 802.11 b/g/n ,2.4Ghz |
GPIO | 19 available GPIO pins have been introduced and peripheral functions are available:ADC,TOUCH,PWM,SPI,I2C,I2S,Pulse counter, RMT,TWAI® Controller,SD/MMC,LCD_CAMERA |
external crystal | 40Mhz |
Buzzer | 8.5x8.5mm buzzer |
LED | 25 Series full color LED lamp, single line GPIO control; 1 monochrome LED, CONTROLLED by GPIO |
photosensitive sensor | 2 photosensitive sensor |
thermosensitive sensor | 1 thermosensitive sensor |
IO | 19pins 19 pin Goldfinger IO(Compatible with Micro :bit accessories ),Crocodile clip bayonet with 19 pin contacts on the back |
Key | 2 Programmable buttons,1 BOOT botton,1 reset key |
USB | USB Type-C interface,full speed USB OTG,USB-ACM |
operating voltage | 3.3V |
Power | USB Type-C input 5V,or Goldfinger IO input 3.3V power supply |
size | 5 * 5 cm |
On-board peripherals
Peripheral GPIO allocation and signal type | ||
photosensitive sensor(L) | GPIO 12 | Analog Input |
photosensitive sensor(R) | GPIO 13 | Analog Input |
Key A | GPIO 38 | Digital Input |
Key B | GPIO 33 | Digital Input |
Key BOOT | GPIO 0 | Digital Input |
thermosensitive sensor | GPIO 14 | Analog Input |
buzzer | GPIO 17 | PWM(Digital Output) |
RGB_LED | GPIO 18 | Digital Output |
5*5 Full color LED lights
BPI-Bit-S2 have 25 Full color LED lights , single GPIO ontrol.The three primary color pixels of each LED can achieve 8bit 256 level brightness display, and achieve 16777216 color full color display, scanning frequency is not less than 400Hz/s.
5*5 LEDs list of BPI-Bit-S2 | ||||
20 | 15 | 10 | 5 | 0 |
21 | 16 | 11 | 6 | 1 |
22 | 17 | 12 | 7 | 2 |
23 | 18 | 13 | 8 | 3 |
24 | 19 | 14 | 9 | 4 |
Goldfinger GPIO define
SPI,I2C | ||
Function | Pin Name | GPIO Num |
SPI_SCK | P13 | GPIO36 |
SPI_MISO | P14 | GPIO37 |
SPI_MOSI | P15 | GPIO35 |
SPI_CS | P16 | GPIO34 |
I2C_SCL | P19 | GPIO16 |
I2C_SDA | P20 | GPIO15 |
Power
Webduino
Arduino
Preparing...
MicroPython
Preparing...
