Banana Pi BPI-M6
Revision as of 11:34, 28 November 2022 by Sinovoip (talk | contribs) (→documents)
Banana Pi BPI-M6 with Synaptics VS680
Banana Pi BPI-M5 Amlogic S905X3 Processor
Banana Pi BPI-M4 Realtek RTD1395
Banana Pi BPI-M64 Allwinner A64
Banana Pi BPI-M2+ Allwinner H3/H5/H2+]3
About VideoSmart VS680
  • Synaptics VideoSmart VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor
  • Imagination GE9920 GPU
  • NPU for AI up to 6 .75Tops
  • 4GB LPDDR4
  • 16GB eMMC flash
  • M.2 Key E(PCIe + MIPI CSI)
  • 4 USB 3.0
  • 1 GbE ethernet
  • 1 HDMIin and 1 HDMIout
HardWare Specification of Banana pi BPI-M6
CPU Synaptics VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor
GPU Imagination GE9920 GPU
NPU for AI Up to 6 .75Tops
Memory 4 GB LPDDR4
Video 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) out, and 1 HDMI in Port
Display MIPI DSI interface
M.2 interface M.2 Key E(PCIe + MIPI CSI)
USB ports USB 3.0 PORT (x4)
Switches SPI boot and U-boot
Power Source 5 volt @3A TYPE C
Size & Weight 92x60mm, 48g
OS Android and Linux
Source code on github
documents
