Banana Pi BPI-R3
![](/images/thumb/2/21/Banana_Pi_BPI-R3_Router_2.jpg/300x300x300px-Banana_Pi_BPI-R3_Router_2.jpg.pagespeed.ic.-Et_Lf5wzB.jpg)
![](/images/thumb/b/bd/Banana_Pi_BPI-R3_3.jpg/300x200x300px-Banana_Pi_BPI-R3_3.jpg.pagespeed.ic.-1kOvJNoVA.jpg)
![](/images/thumb/7/71/Banana_Pi_BPI-R3_with_PoE.jpg/300x225x300px-Banana_Pi_BPI-R3_with_PoE.jpg.pagespeed.ic.fytnjrxSU2.jpg)
![](/images/thumb/7/7a/Banana_Pi_BPI-R2_Pro_1_750.jpg/300x193x300px-Banana_Pi_BPI-R2_Pro_1_750.jpg.pagespeed.ic.ll6IUba5PO.jpg)
![](/images/thumb/c/c0/BPI-R64_3.JPG/300x300x300px-BPI-R64_3.JPG.pagespeed.ic.XEKb2qSGfM.jpg)
![](/images/thumb/0/0a/BPI-R2_3.JPG/300x189x300px-BPI-R2_3.JPG.pagespeed.ic.BBIpfCbXho.jpg)
![](/images/thumb/1/1e/O2A0500.jpg/300x187x300px-O2A0500.jpg.pagespeed.ic.yf1EpBw81x.jpg)
![](/images/thumb/a/a1/Banana_pi_BPI-R1_1.JPG/300x210x300px-Banana_pi_BPI-R1_1.JPG.pagespeed.ic.21RTlyiRZl.jpg)
Application direction
- . Internet service Router
- . Wireless Router
- . Wireless Repeater
- . Home security Gateyway
- . Home Automation
- . Nas device
- . 2G DDR RAM
- . 8G eMMC flash
- . 2 SFP 2.5GbE
- . 5 GbE network port
- . POE support (optional)
- . Mini PCIe via USB
- . M.2 KEY-E PCIe inerface
- . Mciro SD card interfact
- . 26 PIN GPIO
Jumper setting
Jumper Setting of Banana pi BPI-R3 | ||||
Jumper Setting | SW1 | SW2 | SW5 | SW6 |
SPIM-NoR | Low | Low | Low | X |
SPIM-Nand | High | Low | High | X |
eMMC | Low | High | X | Low |
SD card | High | High | X | High |
HardWare Specification of Banana pi BPI-R3 | |||
CPU | MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53+MT7531 chip design | ||
SDRAM | 2 GB LPDDR3 | ||
GPIO | 26 Pin GPIO,some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. | ||
On board Network | 5 Port 10/100/1000Mbps Ethernet | ||
SFP | 2 SFP 2.5GbE | ||
Wifi | Wifi 6/6E 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P) | ||
mini PCIE | Mini PCIe via USB | ||
M.2 interface | M.2 KEY-M PCIe inerface | ||
USB | 1 USB 3.0 host ,2 USB interface with slot. | ||
Buttons | Reset button,WPS botton, boot switch | ||
Sizes | 100.5x148mm same as Banana Pi BPI-R64 and Banana Pi BPI-R2 | ||
Weight | 200g |
- BPI-R3 DXF file : https://drive.google.com/file/d/1PjDbTNHln_RKvPhT9qD6_wbcIe-7yLdT/view?usp=sharing
- BPI-R3 schematic diagram : https://drive.google.com/file/d/1NAyVqpAC2pnt3rBzBz0Jqk-BzQVnsbPb/view?usp=sharing
Release image
- 2022-06-01udptae BPI-R3 OpenWRT 21.02 linux kerne 5.4, wifi 6E 2.4G and 5G working fine.support nand flash ,SD card ,eMMC flash boot. for BPI-R3 production version hardware
- baidu link https://pan.baidu.com/s/1idqU1-bB4XD1LTGDAJxRGA?pwd=chez Pincode: chez
