BPI-Bit-S2
[hide]About BPI:bit Lite
BPI:Bit Lite development board is a successor to BPI:Bit, inheriting most of the core hardware functions.
key features
- ESP32-S2
- 25 full-color LED lights
- 1 temperature sensor
- 1 buzze
- 2 photosensitive sensors
- Two on the front and one programmable button on the back
- Type-C USB interface
- size 5x5cm
- The Goldfinger definition is fully compatible with Micro: Bit
Hardware upgrade and function comparison
BPI:Bit VS BPI:Bit Lite | ||
Module | BPI:Bit | BPI:Bit Lite |
SoC control chip | ESP32 | ESP32-S2 |
ROM | 448 KB | 128 KB |
RAM | 520 KB | 320 KB |
FlASH ROM | 4096 KB | 4096 KB |
PSRAM | None | 2048 KB |
Wireless Capability | WIFI,Bluetooth | WIFI |
all-color LED | 25 WS2812-5050 Lamp beads | 25 WS2812-3535 Lamp beads |
Key | 2 programmable keys,1 RST key | 2 programmable keys,1 BOOT key,1 RST key |
buzzer | 5.3x5.3mm buzzer | 8.5x8.5mm buzzer |
USB interface | Micro USB | Type-C USB |
USB to TTL | support | None |
battery interface | support | None |
IO | 19 pin Goldfinger IO(Compatible with Micro :bit accessories ) | 19 pin Goldfinger IO(Compatible with Micro :bit accessories ),Crocodile clip bayonet with 19 pin contacts on the back |
Nine-axis sensor | support | None |
photosensitive sensor | 2 | 2 |
temperature sensor | 1 | 1 |
BPI:Bit Lite specification | |
SoC | ESP32-S2FN4R2,Xtensa® 32 bit LX7 Single-Core Processer |
frequency | 240MHz MAX |
operating temperature | -40℃~+85℃ |
ROM | 128 KB |
SRAM | 320 KB |
FLASH ROM | 4 MB |
PSRAM | 2 MB |
WIFI | IEEE 802.11 b/g/n ,2.4Ghz |
GPIO | 19 available GPIO pins have been introduced and peripheral functions are available:ADC,TOUCH,PWM,SPI,I2C,I2S,Pulse counter, RMT,TWAI® Controller,SD/MMC,LCD_CAMERA |
external crystal | 40Mhz |
Buzzer | 8.5x8.5mm buzzer |
LED | 25 Series full color LED lamp, single line GPIO control; 1 monochrome LED, CONTROLLED by GPIO |
photosensitive sensor | 2 photosensitive sensor |
photosensitive sensor | 1 photosensitive sensor |
IO | 19pins 19 pin Goldfinger IO(Compatible with Micro :bit accessories ),Crocodile clip bayonet with 19 pin contacts on the back |
Key | 2 Programmable buttons,1 BOOT botton,1 reset key |
USB | USB Type-C interface,full speed USB OTG,USB-ACM |
operating voltage | 3.3V |
Power | USB Type-C input 5V,or Goldfinger IO input 3.3V power supply |
size | 5 * 5 cm |
On-board peripherals
Peripheral GPIO allocation and signal type | ||
photosensitive sensor(L) | GPIO 12 | Analog Input |
photosensitive sensor(R) | GPIO 13 | Analog Input |
Key A | GPIO 38 | Digital Input |
Key B | GPIO 33 | Digital Input |
Key BOOT | GPIO 0 | Digital Input |
temperature sensor | GPIO 14 | Analog Input |
buzzer | GPIO 17 | PWM(Digital Output) |
RGB_LED | GPIO 18 | Digital Output |
5*5 Full color LED lights
BPI:Bit V2 have 25 Full color LED lights , single GPIO ontrol.The three primary color pixels of each LED can achieve 8bit 256 level brightness display, and achieve 16777216 color full color display, scanning frequency is not less than 400Hz/s.
5*5 LEDs list of BPI:Bit V2 | ||||
20 | 15 | 10 | 5 | 0 |
21 | 16 | 11 | 6 | 1 |
22 | 17 | 12 | 7 | 2 |
23 | 18 | 13 | 8 | 3 |
24 | 19 | 14 | 9 | 4 |
Goldfinger GPIO define
BPI:Bit Lite Gold finger GPIO is defined to be compatible with Micro :Bit. GPIO expansion board accessories can be used with Micro: Bit.
SPI,I2C | ||
Function | Pin Name | GPIO Num |
SPI_SCK | P13 | GPIO36 |
SPI_MISO | P14 | GPIO37 |
SPI_MOSI | P15 | GPIO35 |
SPI_CS | P16 | GPIO34 |
I2C_SCL | P19 | GPIO16 |
I2C_SDA | P20 | GPIO15 |
Power
BPI:Bit Lite supports two power supply modes
Webduino
Arduino
Preparing...
MicroPython
Preparing...
