Getting Started with M2S
Revision as of 19:15, 27 June 2022 by Dangku (talk | contribs) (Enable Camera)
4. Only A311D variant board have camera, mipi panel and npu support.
2. Press and hold USB button on the board, plugin type-c usb cable to PC or press the RST button if power adapter already connected, about two seconds later, release the button, the board will be identified correctly.
Android DTB overlay
Bananapi M2S DTBO idx value table, default idx value is 0 in release image.
2 i2c1 enable i2c 1
3 i2c2 enable i2c 2
4 sdio enable sdio
5 uart1 enable 2 pins uart 1
7 uart2 enable 2 pins uart 2
How to apply a new dtbo
1. ADB command via sysfs
 restarting adbd as root
 remount succeeded
 bananapi_m2s:/ # reboot
 console:/ $
 console:/ $ su
 console:/ #
 console:/ #
 console:/ # reboot
3. Settings App(To-Do)
       Amlogic multi-dtb tool
       Single dtb detected
 find 2 dtbos
 dtbos to be applied: 1
 Apply dtbo 1
Install OpenGapps
2. Download device_id.apk.
udisk:
 --wipe_cache
sdcard:
 --wipe_cache
watch this video on bilibili
Switch Mipi Panel
Panel Rotation
   index 1f51703..d592a44 100644
    else
        ro.sf.lcd_density=213 \
    endif
   index 4a698b0..3d41b63 100755
   @@ -876,8 +876,8 @@
                   reg = <0x5d>;
4. Extract this tool
 $ ls -l logo/
5. Copy the boot-logo.bmp.gz
 $ adb root
 $ adb remount
 $ adb reboot fastboot
 $ fastboot device
 1234567890      fastboot
 $ fastboot reboot
 $ apt-get install pv
Install Image to SDcard
2. Install the linux image in udisk with bpi-tools on Linux, plug SDcard to Linux PC and run
3. Install Image with dd command on Linux, umount SDcard device /dev/sdX partition if mounted automatically. Actually bpi-copy is the same as this dd command.
 $ sudo apt-get install pv
 $ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
Install Image to EMMC
4. Install with dd command, umount mmcblk0p1 and mmcblk0p2 partition if mounted automatically. Actually bpi-copy is the same as this dd command.
 $ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
Build Linux Source Code
2. Build the bsp source code
 i2c1.dtbo           pwm_ef.dtbo           waveshare_tft24_lcd.dtbo
 i2c2.dtbo           pwm_ef-f.dtbo         waveshare_tft35c_lcd.dtbo
 # Device Tree Overlays
 overlays="i2c2 spi0 uart1"
Enable Camera
The linux release image is not enable camera default, according to the following configuration, it can be enabled by yourself.
 overlays="os08a10"
 iv009_isp_iq
 iv009_isp_lens
 iv009_isp_sensor
 iv009_isp
 #choose isp register sequence
Switch Mipi Panel
 # Mipi panel type
 #    Symbol    | Resolution
 panel_type=lcd_0
Panel Rotation
The two 10" mipi panels are all portrait hw display, so the default release image is portrait mode, but you can rotate it to 90/180/270. Create a xorg configuration file /usr/share/X11/xorg.conf.d/10-fbdev-rotate.conf with contents:
 Section "Device"
     # Rotate off
 #   Option "Rotate" "off"
     Option "Rotate" "CW"
 #   Option "Rotate" "UD"
 #   Option "Rotate" "CCW"
 EndSection
 Section "InputClass"
     MatchIsTouchscreen "on"
     MatchProduct "goodix-ts"
     MatchDriver "libinput"
 EndSection
Note: This WiringPi only support set 40pin gpio to output, input, pwm or software pwm, for io functions as i2c, spi, ..., you must enable dtb overlay in boot.ini
1. Build and install wiringPi
 $ cd amlogic-wiringPi
 $ chmod a+x build
 $ sudo ./build
Build and install
 $ cd RPi.GPIO-Amlogic
WiringPi2-Python
Build and install
 $ sudo apt-get Install python python-dev python-setuptools swig wiringpi git
 $ git clone https://github.com/Dangku/WiringPi2-Python-Amlogic.git
 $ cd WiringPi2-Python-Amlogic
Boot Sequence
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 Use GP1_pll as DSU clk.
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 board id: 1
 fw parse done
 PIEI prepare done
 fastboot data verify
 result: 255
 DDR4 probe
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 eMMC boot @ 0
 sw8 s
 board id: 1
 fw parse done
 PIEI prepare done
 00000000
 emmc switch 1 ok
 ddr saved addr:00016000
 00000000
   remount succeeded
   1234567890	fastboot
   OKAY [  0.044s]
   finished. total time: 0.044s
   OKAY [  0.047s]
   finished. total time: 0.047s
   erasing 'bootloader'...
   OKAY [  0.059s]
   finished. total time: 0.059s
   erasing 'bootloader-boot0'...
   OKAY [  0.036s]
   finished. total time: 0.036s
   erasing 'bootloader-boot1'...
   OKAY [  0.035s]
   finished. total time: 0.035s
   start = 0,end = 57343
   start = 221184,end = 30535679
   start = 0,end = 8191
   bananapi_m2s_v1#reset
   resetting ...
   BPI: try boot from sdcard
   reading boot.ini
   Starting boot.ini...
   reading env.txt
   HDMI: Autodetect: 1080p60hz
   reading Image.gz
   reading bananapi_m2s.dtb
   reading uInitrd
 $ sync
Wifi/BT support
1. Android test and support.
 rtl8723bu wifi/bt(usb)
 rtl8188eu wifi(usb)
 rtl8821cu wifi/bt(usb)
 rtl8822cs wifi/bt(sdio/uart)
How to enable Android Wifi/BT
2. Linux test and support.
 rtl8188eu wifi(usb)
 rtl8192eu wifi(usb)
 rtl8811au wifi(usb)
 rtl8812au wifi(usb)
 rtl8812bu wifi(usb)
How to enable Linux Wifi
SDIO/UART type:
2). Configure the dtb overlay
   overlays="wifi_bt_rtl8822cs"
How to enable Linux Bluetooth
Cloud-init&Snap
or
 $ sudo apt purge cloud-init
2. disable or remove snap
 $ sudo apt purge snapd
Enable rc-local
 [Unit]
 After=network.target
 [Service]
 Type=forking
 ExecStart=/etc/rc.local start
 TimeoutSec=0
 RemainAfterExit=yes
 GuessMainPID=no
 [Install]
 WantedBy=multi-user.target
 Alias=rc-local.service
Create /etc/rc.local file.
 sudo nano /etc/rc.local
 #!/bin/sh
 # rc.local
 # value on error.
 # bits.
 exit 0
 $ sudo chmod +x /etc/rc.local
 $ sudo reboot
Install Docker Engine
1. Set up the repository
 $ sudo apt-get update
Set up the stable repository
 $  echo \
2. Install Docker Engine
 $ sudo docker run hello-world
