Banana Pi BPI-M2S
Revision as of 10:59, 28 June 2022 by Dangku (talk | contribs) (→Ubuntu)
BPI-M2S Introduction
BPI-M2S with Wifi&BT module
BananaPi BPI-M2S new design with Amlogic A311D Quad core ARM Cortex-A73 and dual core ARM Cortex-A53 CPU ,ARM G52 MP4(6EE) GPU,NPU for AI at 5.0 TOPS, support Camera and MIPI-CSI interface ,HDMI output,2 Gigabit port . 4G RAM and 16 GB eMMC flash.Amlogic S922X variant M2S board is not support npu, mipi panel and mipi camera.BPI-M2S same size as Banana Pi BPI-M2+ and Banana Pi BPI-M2 Pro
  • 4GB LPDDR4 RAM
  • 16GB eMMC flash (Max 128G)
  • 2 Gigabit port
  • HDMI output
  • 40 PIN GPIO
  • System Memory – 4GB LPDDR4
  • Video interfaces
HDMI 2.1 output up to 4Kp60
MIPI CSI connector for camera
  • Networking – 2x Gigabit Ethernet ports one via RTL8211F GbE transceiver, the other through RTL8111H PCIe to Gigabit Ethernet transceiver
  • USB – 1x USB 2.0 Type-A port, 1x USB Type-C port
  • Expansion – 40-pin GPIO header
  • Misc – 3x buttons
  • Dimensions – 65 x 65mm
PoE Wifi&BT
BPI-M2S 40PIN GPIO (CON2)
GPIO Pin Name Default :GPIO Function2 Function3
CON2-P01 VCC-3V3
CON2-P02 DCIN
CON2-P03 GPIOX_17 I2C_EE_M2_SDA BT_EN
CON2-P04 DCIN
CON2-P05 GPIOX_18 I2C_EE_M2_SCL BT_WAKE_HOST
CON2-P06 GND
CON2-P07 GPIOX_5 PWM_C WIFI_SD_CMD
CON2-P08 GPIOX_12 UART_EE_A_TX
CON2-P09 GND
CON2-P10 GPIOX_13 UART_EE_A_RX
CON2-P11 GPIOX_3 WIFI_SD_D3
CON2-P12 GPIOA_1 I2SB_SCLK
CON2-P13 GPIOX_4 WIFI_SD_CLK
CON2-P14 GND
CON2-P15 GPIOX_7 WIFI_WAKE_HOST
CON2-P16 GPIOX_0 WIFI_SD_D0
CON2-P17 VCC-3V3
CON2-P18 GPIOX_1 WIFI_SD_D1
CON2-P19 GPIOX_8 SPI_A_MOSI BTPCM_DIN
CON2-P20 GND
CON2-P21 GPIOX_9 SPI_A_MISO BTPCM_DOUT
CON2-P22 GPIOX_2 WIFI_SD_D2
CON2-P23 GPIOX_11 SPI_A_CLK BTPCM_CLK
CON2-P24 GPIOX_10 SPI_A_CS BTPCM_SYNC
CON2-P25 GND
CON2-P26 GPIOX_16 BT_32K
CON2-P27 GPIOH_5
CON2-P28 GPIOH_4
CON2-P29 GPIOX_14 BTUART_A_CTS_N
CON2-P30 GND
CON2-P31 GPIOX_15 BTUART_A_RTS_N
CON2-P32 GPIOX_19 HOST_WAKE_BT
CON2-P33 GPIOX_6 WIFI_PWREN
CON2-P34 GND
CON2-P35 GPIOA_2 I2SB_LRCLK
CON2-P36 GPIOAO_5 IR_IN
CON2-P37 GPIOA_0 I2S_MCLK_0
CON2-P38 GPIOA_4 I2SB_DOUT_DIN_1
CON2-P39 GND
CON2-P40 GPIOA_3 I2SB_DOUT_DIN_0
BPI-M2S Debug UART(CON1)
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
BPI-M2S Camera(CN10)
CN10-P01 GND
CN10-P02 MIPI_CSI_D3N
CN10-P03 MIPI_CSI_D3P
CN10-P04 GND
CN10-P05 MIPI_CSI_D2N
CN10-P06 MIPI_CSI_D2P
CN10-P07 GND
CN10-P08 MIPI_CSI_CLKBN
CN10-P09 MIPI_CSI_CLKBP
CN10-P10 GND
CN10-P11 MIPI_CSI_D1N
CN10-P12 MIPI_CSI_D1P
CN10-P13 GND
CN10-P14 MIPI_CSI_D0N
CN10-P15 MIPI_CSI_D0P
CN10-P16 GND
CN10-P17 MIPI_CSI_CLKAN
CN10-P18 MIPI_CSI_CLKAP
CN10-P19 NC
CN10-P20 CAM0_MCLK
CN10-P21 CAM0_IRCUT
CN10-P22 CAM0_SCL
CN10-P23 CAM0_SDA
CN10-P24 CAM0_RESET
CN10-P25 VCC1V8_DOVDD
CN10-P26 GND
CN10-P27 GND
CN10-P28 VCC33
CN10-P29 VCC33
CN10-P30 VCC33
BPI-M2S LCD(CN9)
CN9-P01 MIPI_D0_N
CN9-P02 MIPI_D0_P
CN9-P03 MIPI_D1_N
CN9-P04 MIPI_D1_P
CN9-P05 MIPI_CLK_N
CN9-P06 MIPI_CLK_P
CN9-P07 MIPI_D2_N
CN9-P08 MIPI_D2_P
CN9-P09 MIPI_D3_N
CN9-P10 MIPI_D3_P
CN9-P11 TP_INT_3V3
CN9-P12 TP_RST_3V3
CN9-P13 I2C_M3_SCL_3V3
CN9-P14 I2C_M3_SDA_3V3
CN9-P15 LCD_BL_EN_3V3
CN9-P16 LCD_PWM_3V3
CN9-P17 GND
CN9-P18 GND
CN9-P19 VLCD_5V
CN9-P20 VLCD_5V
How to flash Android Image
  • 2021-06-13 release, Android 9.0 with kernel 4.9.113.
Download: 2022-06-13-bpi-m2s-android9.zip
MD5: 9ed872402bc14ac2528990b2d6c41eff
How to flash Linux Image
  • 2022-06-20 release, Ubuntu Mate Desktop 20.04 with kernel 4.9.241
Download: [ 2022-06-20-ubuntu-20.04-mate-desktop-bpi-m2s-aarch64-sd-emmc.img.zip]
MD5: 2945f225eadba1b350cd49f47817c0cd
  • 2022-06-20 release, Ubuntu Server 20.04 with kernel 4.9.241
Download: [ 2022-06-20-ubuntu-20.04-server-bpi-m2s-aarch64-sd-emmc.img.zip]
MD5: 9b17a00cbc17c46e414a906e659e7ca2
  • 2022-06-20 release, Debian Buster with kernel 4.9.241
Download: 2022-06-20-debian-10-buster-bpi-m2s-aarch64-sd-emmc.img.zip
MD5: 9d39558ad37e5da47d7d144c8afec45e
