Getting Started with M2S
Revision as of 23:01, 13 June 2022 by Dangku (talk | contribs) (Dangku moved page Getting Started with BPI-M2S to Getting Started with M2S)
- 4. Only A311D variant board have camera, lcd/tp, npu support.
$ git clone https://github.com/Dangku/BPI-A311D-Android9
Android DTB overlay
- How to apply a new dtbo
- 1. ADB command via sysfs
- 3. Settings App(To-Do)
Amlogic multi-dtb tool
Single dtb detected
find 2 dtbos
dtbos to be applied: 1
Apply dtbo 1
Install OpenGapps
- 2. Download device_id.apk.
- udisk:
- sdcard:
Switch Mipi Panel
Panel Rotation
index 1f51703..d592a44 100644
else
ro.sf.lcd_density=213 \
endif
index 4a698b0..3d41b63 100755
@@ -876,8 +876,8 @@
reg = <0x5d>;
Custom Android Boot Logo
- 4. Extract this tool
Install Image to SDcard
$ sudo apt-get install pv $ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
Install Image to EMMC
$ sudo apt-get install pv $ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
Build Linux Source Code
$ git clone https://github.com/Dangku/BPI-M2S-bsp
root@bananapi:~# ls /boot/firmware/overlays/ custom_ir.dtbo pwm_b-backlight.dtbo spi0.dtbo ds3231.dtbo pwm_c-beeper.dtbo uart1_cts_rts.dtbo hifi_pcm5102a.dtbo pwm_cd-c.dtbo uart1.dtbo hifi_pcm5122.dtbo pwm_cd.dtbo uart2.dtbo i2c1.dtbo pwm_ef.dtbo waveshare_tft24_lcd.dtbo i2c2.dtbo pwm_ef-f.dtbo waveshare_tft35c_lcd.dtbo pwm_ab.dtbo sdio.dtbo waveshare_tft35c_rtp.dtbo
Enable Camera
- Update the dtb overlays env in vfat /boot/env.txt to enable camera.
# Device Tree Overlays # uart1 -- Enable UART1 (uart_A, GPIO Header PIN8 & PIN10) # pwm_c -- Enable PWM_C (GPIO Header PIN7) # i2c2 -- Enable i2c2 (GPIO Header PIN3 & PIN5) # spi0 -- Enable SPI0 (GPIO Header PIN19 & PIN21 & PIN23 & PIN24) overlays="os08a10"
Switch Mipi Panel
- Build and install
WiringPi2-Python
- Build and install
Custom Linux Boot Logo
Boot Sequence
Wifi/BT support
- 2. Linux test and support.
- How to enable Linux Wifi
- SDIO/UART type:
overlays="wifi_bt_rtl8822cs"
Cloud-init&Snap
- or
$ sudo apt purge cloud-init
- 2. disable or remove snap
$ sudo apt purge snapd
Install Docker Engine
- 1. Set up the repository
$ echo \
- 2. Install Docker Engine
$ sudo docker run hello-world
