Banana Pi BPI-M2 ZERO
![](/images/thumb/d/d2/BPI-F2_zero_1.JPG/300x237x300px-BPI-F2_zero_1.JPG.pagespeed.ic.B1JUagsFSj.jpg)
![](/images/thumb/9/9e/Newwork_scu.JPG/300x236x300px-Newwork_scu.JPG.pagespeed.ic.n5XH1yc_zv.jpg)
for Allwinner H2+ chip is EOL, so BPI-M2 Zero will use H3 chip defaults. but image for H2+ also support H3, so all image is same. support H2+ and H3 chip.
- 512MB DDR 3 SDRAM.
- Mini HDMI.
IR | N/A | N/A | N/A |
Weight | 30g | 15g | 9g |
CON2-P01 | VCC-3V3 | ||
CON2-P02 | VCC-5V | ||
CON2-P04 | VCC-5V | ||
CON2-P06 | GND | ||
CON2-P09 | GND | ||
CON2-P14 | GND | ||
CON2-P17 | VCC-3V3 | ||
CON2-P18 | PC4 | PC4 | |
CON2-P20 | GND | ||
CON2-P23 | SPI0-CLK | PC2 | |
CON2-P24 | SPI0-CS | PC3 | |
CON2-P25 | GND | ||
CON2-P26 | PC7 | PC7 | |
CON2-P30 | GND | ||
CON2-P34 | GND | ||
CON2-P39 | GND | ||
CN3-P01 | NC | ||
CN3-P02 | GND | ||
CN3-P03 | CSI0-SDA | PE13 | |
CN3-P04 | CSI0-AVDD | ||
CN3-P05 | CSI0-SCK | PE12 | |
CN3-P10 | CSI0-DVDD | ||
CN3-P11 | CSI0-DOVDD | ||
CN3-P12 | CSI0-D7 | PE11 | |
CN3-P13 | CSI0-MCLK | PE1 | |
CN3-P14 | CSI0-D6 | PE10 | |
CN3-P15 | GND | ||
CN3-P16 | CSI0-D5 | PE9 | |
CN3-P17 | CSI0-PCLK | PE0 | |
CN3-P18 | CSI0-D4 | PE8 | |
CN3-P19 | CSI0-D0 | PE4 | |
CN3-P20 | CSI0-D3 | PE7 | |
CN3-P21 | CSI0-D1 | PE5 | |
CN3-P22 | CSI0-D2 | PE6 | |
CN3-P23 | GND | ||
CN3-P24 | CSI0-DOVDD |
CON3 P01 | GND |
PIN define:
schematic diagram:
test
Zero power with GPIO 5V input
- Allwinner documents:
- Android 4.4 source code
- Linux source code
- Forum pthread:
Arch Linux
- Image Link:
- Forum thread:
RetroPie
retrorangepi
Raspbian
- Image Links:
- HDMI-Version
- Image Links:
- HDMI-Version
- 2018-07-09 update
- Image Link:
- 2017-11-13 update
Nuevas
- Nuevas imagenes BPI-M2 Zero
