Banana Pi BPI-M2U
Banana Pi BPI-M2 Ultra is a quad-core mini single board computer built with Allwinner A40i/R40/V40 SoC. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, a DC power port, and last but not least, a SATA port.. Also being a member of the Banana Pi family, the M2 Ultra is a direct upgrade from the Banana Pi M1/M1+ that support SATA from the SoC. The SATA performance on the R40 is fitting for media related projects such as storage servers. Backed by our community, starting a project and building servers is fun and rewarding. We welcome all companies, DIYers, and tech loving people within our community! Together, we can make a difference, we can discover our passions, inspire others, and build a practical project.
- Allwinner A40i/R40/V40 Quad Core ARM Cortex A7 CPU
- 2GB DDR3 SDRAM.
- 8GB eMMC flahs onboard.
- SATA Interface.
- 2*USB 2.0
- MIPI DSI ingerface
- CSI camera interface
| Soc | Allwinner R40/V40 | ||
| SDRAM | 2 GB DDR3 with 733MHz\(shared with GPU\) | ||
| Bluetooth | BT4.0 | ||
| Audio outputs | HDMI, analog audio \(via 3.5 mm TRRS jack\) | ||
| USB | 2 USB 2.0 host, 1 USB 2.0 OTG | ||
| DC Power | 5V/2A with DC port | ||
| battery | 3.7V lithium battery power support | ||
| Weight | 40g | ||
| 40 PIN GPIO of Banana pi BPI-M2 Ultra | |||
| CON1-P01 | VCC-3V3 | ||
| CON1-P02 | DCIN | ||
| CON1-P04 | DCIN | ||
| CON1-P06 | GND | ||
| CON1-P09 | GND | ||
| CON1-P11 | UART7-TX | PI20 | PWM2 |
| CON1-P14 | GND | ||
| CON1-P17 | VCC-3V3 | ||
| CON1-P20 | GND | ||
| CON1-P25 | GND | ||
| CON1-P30 | GND | ||
| CON1-P34 | GND | ||
| CON1-P39 | GND | ||
| CSi Camera connector GPIO of Banana pi BPI-M2 Ultra | |||
| CN5-P01 | NC | ||
| CN5-P02 | GND | ||
| CN5-P04 | CSI0-AVDD | ||
| CN5-P10 | CSI0-DVDD | ||
| CN5-P11 | CSI0-DOVDD | ||
| CN5-P15 | GND | ||
| CN5-P16 | CSI0-D5 | PE9 | |
| CN5-P18 | CSI0-D4 | PE8 | |
| CN5-P19 | CSI0-D0 | PE4 | |
| CN5-P20 | CSI0-D3 | PE7 | |
| CN5-P21 | CSI0-D1 | PE5 | |
| CN5-P22 | CSI0-D2 | PE6 | |
| CN5-P23 | GND | ||
| CN5-P24 | CSI0-AFVCC | ||
Display specification
| CN6-P01 | VCC-3V3 | ||
| CN6-P02 | IPSOUT | ||
| CN6-P03 | VCC-3V3 | ||
| CN6-P04 | IPSOUT | ||
| CN6-P05 | GND | ||
| CN6-P06 | IPSOUT | ||
| CN6-P07 | GND | ||
| CN6-P08 | IPSOUT | ||
| CN6-P09 | NC | ||
| CN6-P10 | GND | ||
| CN6-P11 | NC | ||
| CN6-P12 | DSI-D0N | ||
| CN6-P13 | NC | ||
| CN6-P14 | DSI-D0P | ||
| CN6-P15 | NC | ||
| CN6-P16 | GND | ||
| CN6-P18 | DSI-D1N | ||
| CN6-P20 | DSI-D1P | ||
| CN6-P22 | GND | ||
| CN6-P24 | DSI-CKN | ||
| CN6-P25 | GND | ||
| CN6-P26 | DSI-CKP | ||
| CN6-P28 | GND | ||
| CN6-P30 | DSI-D2N | ||
| CN6-P32 | DSI-D2P | ||
| CN6-P33 | GND | ||
| CN6-P34 | GND | ||
| CN6-P35 | LCD-PWM | PB2 | |
| CN6-P36 | DSI-D3N | ||
| CN6-P37 | GND | ||
| CN6-P38 | DSI-D3P | ||
| CN6-P39 | NC | ||
| CN6-P40 | GND | ||
| CON4 Uart GPIO of Banana pi BPI-M2 Ultra | |||
| CON2 P03 | UART0-TXD | ||
| CON2 P02 | UART0-RXD | ||
| CON2 P01 | GND | ||
- Banana Pi BPI-M2 Ultra / BPI-M2 Berry How to alter Uboot、Kernel
- How to boot from emmc with SD data
- How to rebuild bootloader BPI_M2U_720P-emmc.img.gz
- Supports Banana Pi BPI-M2 Ultra (R40) (Kernel3.10)
- BPI official github:https://github.com/BPI-SINOVOIP/BPI-M2U-bsp
- other github for BPI-M2 Ultra /Berry : https://github.com/facat/BPI-M2U-bsp
- BPI-M2 Ultra/Berry TinaLinux github https://github.com/tinalinux/linux-3.10
- Android 6.0 source code: https://github.com/BPI-SINOVOIP/BPI-R40-V40-Android6
- BPI-M2 Ultra Schematics :google driver
- Allwinner R40/V40 datasheet
Android 6.0
- 2019-05-15 update R40 & V40 Android 6.0.1 HDMI & LCD7**
- Features Map:http://wiki.banana-pi.org/M2U/Berry_Image_Map#Android_6.0.1_HDMI_.26_LCD7
- HDMI Version Image Links:
- Google Drive : https://drive.google.com/open?id=1na_-HkPTGzhYAMvmx7zCC4Zo77HQ0FwT
- Baidu Drive : https://pan.baidu.com/s/1fGw-zHIS0DTR7ta60UpdeA (PinCode:ltp6)
- LCD7 Version Image Links:
- Google Drive : https://drive.google.com/open?id=1XttsrYyYUsTzwuFOctr59HvCiXSR6w7O
- Baidu Drive : https://pan.baidu.com/s/1-SOdpY4ioCk5NY1SsII6EQ (PinCode:6s3f)
- Forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m2u-new-image-all-chips-android6-new-image-release-2019-05-15/9135
- 2019-04-24 update BPI-M2 Ultra Android 6.0.1 HDMI & LCD7
- Features Map :http://wiki.banana-pi.org/M2U/Berry_Image_Map#Android_6.0.1_HDMI_.26_LCD7
- Google Drive : https://drive.google.com/open?id=1sKRROwW32lgdefgo6NjgAR2_M5zfr2px
- Baidu Drive : https://pan.baidu.com/s/1qLHE9o6XT9M5HDF6YtOcuA (PinCode:c103)
- Google Drive : https://drive.google.com/open?id=1H_Dof-A_0BYfg2MMa2okggDAcbIleGvY
- Baidu Drive : https://pan.baidu.com/s/1d9BE1rzXFKuQapsHu2ZdLA (PinCode:zy4b)
- Forum pthread:http://forum.banana-pi.org/t/banana-pi-bpi-m2u-a40i-android6-new-image-release-2019-04-24/9135
- 2018-12-28 update
- HDMI-Version
- BaiDu Drive:https://pan.baidu.com/s/1_ec1SHxr87lV9j9sJ_vTkg PinCode:gavs
- LCD7-Version
- BaiDu Drive:https://pan.baidu.com/s/1vGiLql0-WSGMqQFMFjtMRA PinCode:wqt6
- 2017-08-25 update
- HDMI-Version
- MD5: c65fa4c20b8a6d2d05bfd32b090c3570
- LCD5-Version
- MD5:f664e5fe0af20ebfc06ddc50bac1845b
- LCD7-Version
- MD5: 6cda3453d9524643c8f92fcdc8deb32f
- 2022-04-16 Banana Pi new image: Ubuntu 16.04 with Allwinner BSP, use MPV play 1080P video,Allwinner BSP kernel 3.4 , BPI-M2 Ultra/Berry use kernel 3.10
- 2020-04-19 update, kernel 3.10.108
- Desktop images:
- Google Drive : https://drive.google.com/open?id=1TpRMMcm50kQTXOOLXp65npTWovd7jCYc
- Baidu Drive : https://pan.baidu.com/s/1-8nAN7RXVqVbJg3CUQnRzQ (PinCode:fnpt)
- Server images:
- Desktop images:
- baidu cloud : https://pan.baidu.com/s/1xRReFsjaOAYx9xEl0_BNWA PinCode:myu5
- 2017-11-13 update
- baidu cloud : https://pan.baidu.com/s/1xls34tILr9f4I5FUZ1Gtpw PinCode:trmk
- Desktop images :
- Google Drive :
- Server images:
- 2017-11-13 update debian-9-stretch-mate-desktop
- Google Drive : https://drive.google.com/file/d/0B_YnvHgh2rwjeTh4TmlnMGl5X3M/view?usp=sharing
- baidu cloud : https://pan.baidu.com/s/1Kv2S0TqUX49rEbbQgiP_bQ PinCode:v6m4
- MD5: 0a1fad281c24902148b16276a79bac12
- 2017-11-13 update debian-9-stretch-lite
- Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjOWg1OW9heWZsYm8/view?usp=sharing
- baidu cloud: https://pan.baidu.com/s/1gE0a4ckTRrRXRbIX8uQzNg PinCode:5vnb
- MD5: cff677aa94ca5345fc6e26379cfe4e95
- forum pthread : http://forum.banana-pi.org/t/bpi-m2-ultra-bpi-m2-berry-new-image-2017-08-28-debian-sd-emmc-img/3745/2
Raspbian
- Raspbian stretch Download
- Desktop image :
- Google Drive : https://drive.google.com/open?id=16bDXcoKycZSGQgzh-L3bQYBpEs8HtRZF
- Baidu Drive : https://pan.baidu.com/s/115a-o-qKxI3YDkEAdmGevQ (PinCode:6hxx)
- 2017-05-25 update raspbian jessie
- Google Drive :https://drive.google.com/open?id=1Ntdh5tMyCjiAu8bBC9NC2ShEAYAAD0tD
- baidu cloud :https://pan.baidu.com/s/1i4YdcBeVvMyl530WHzArzA PinCode:l1rn
- MD5: 60e19ea9138d6841fa6852ece4727b0a
- forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m2-ultra-bpi-m2-berry-new-image-2017-05-25-raspbian-jessie-preview3-bpi-m2u-sd-emmc-img/3306
Tina IoT Linux
OpenWRT Linux
- OpenWrt has test images for Banana Pi M2 Ultra, available at the following link:
LibreElec
- LibreElec has test images for Banana Pi M2 Ultra, available at the following link:
- download link:https://test.libreelec.tv
- Discuss on forum : http://forum.banana-pi.org/t/libreelec-image-for-bpi-m2ultra/11635
RPiTC v3 1.12
- 2017-11-28 updtae
Others
