Banana Pi BPI-R2 Pro
Revision as of 03:49, 28 April 2022 by Sinovoip (talk | contribs) (Android)
Rockchip RK3568 chip
BPI-R2 Pro case same as BPI-R2
BPI-RK3588 Core board and development Kit
  • Mali-G52 1-Core-2EE
  • 2G LPDDR4 SDRAM (option 4G)
  • support 1 SATA interface
  • 1 CSI camera interface
Rockchip RK3568
Banana Pi R2 Pro
Storage Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port,SPI flash
Camera 1 CSI camera interfact
Video decoder(s) H.265 HEVC/MVC Main10 Profile [email protected] up to 4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps
Video encoder(s) H.264/AVC BP/MP/[email protected],up to 1920x1080@100fps, H.265/HEVC [email protected], up to 1920x1080@100fps (4096x4096@10fps with TILE)
Remote IR Receiver (x1)
LED Power Status and 8P8C
Source Code
documents
Release image
All image for BPI-R2 Pro : Baidu :https://pan.baidu.com/s/1Vh-GfYM8OgnbipW5dDQkTQ Pincode:6yvx
ubuntu 21.04
  • ubuntu 21.04 linux kernel 4.19 image 2022-3-10 update
google driver: https://drive.google.com/drive/folders/1pFayiLS3cS0idClUlvHzaySaJMb_AOrB
baidu link: https://pan.baidu.com/s/1fNlnH-5lTHOo-_Eqg9JFHA?pwd=2b7u pincode: 2b7u
video and boot log:https://forum.banana-pi.org/t/banana-pi-bpi-r2-pro-openwrt-ubuntu-debian-linux-image/13158
OpneWRT
  • OpenWRT-21.02 linux kernel 4.19 image, 2022-3-10 update
google driver: https://drive.google.com/drive/folders/10HzNC0pWhS8j3W7uaFQ5RGO7UK133Xt-
baidu link: https://pan.baidu.com/s/1g-wZsPUB68mCgXEf2RrIkw?pwd=8cxu pincode: 8cxu
  • Debian 10 linux kernel 4.19 image, 2022-3-10 update
google driver: https://drive.google.com/drive/folders/1LSJlHtkHC_Ua6zVgVI3BRJOVPUb6vWO6
baidu link: https://pan.baidu.com/s/16LpV0YXJ3WYhIFKZjAv_sw?pwd=c7pd pincode: c7pd
