BPI-9460 IEEE 802.3af Isolation Model PoE moduleBPI-9460 IEEE 802.3af Isolation Model PoE module
The BPI-9460 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard.
The BPI-9460 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 15W power to the port. The RT9460 provides a Class 0 signature.The DC/DC converter operates over a wide input voltage range and provides a regulated output. The DC/DC converter also has built-in short-circuit output protection.
Applications
IP Cameras
Wireless access point
Security and alarm systems
VOIP telephone
Point of sale network terminal equipment
Features
IEEE802.3af compliant
Input voltage range 36V to 57V
Integral high efficiency DC/DC converter.
Low output ripple and noise
High performance with low price
Short-circuit protection
Adjustable Output
Optional multi-voltage output 3.3V 5V 12V 24V
Transformer isolation ,1500V isolation (input to output)
Easy to use, with a minimum number of external components.
Rohs compliantnt
BPI-9460 Product Selector
Part Number
Nominal Output Voltage
Output current
Maximum Output Power*
Marking
Package
BPI-9460S-3.3V
3.3V
2A
10W**
3.3V
SIL
BPI-9460S -5V
5V
2.4A
13W**
5V
SIL
BPI-9460S -12V
12V
1A
13W**
12V
SIL
BPI-9460S -24V
24V
0.5A
13W**
24V
SIL
At 25°C with VIN = 48V
Maximum Output Power: means it not could be operated in continuous stage .only short-term of Boot up/Heavy loading
Absolute Maximum Ratings
Parameter
Symbol
Min
Max
Units
DC Supply Voltage
VCC
-0.3
60
V
2
DC Supply Voltage Surge for 1ms
VSURGE
-0.6
80
V
3
Storage Temperature
TS
-40
100
OC
Parameter
Symbol
Min
Typ
Max
Units
Input Supply Voltage1
VIN
36
48
57
V
2
Under Voltage Lockout
VLOCK
30
36
V
3
Operating Temperature2
TOP
-20
25
70
Ta / OC
Note
1: With minimum load
2: See Section Operating Temperature Range
Extended use close to, or at the maximum operating temperature can reduce the life time of the device.
Pin Description:
Pin #
Name
Description
VA1
RX Input (1). This input pin is used in conjunction with VA2 and connects to the centre tap of the transformer connected to pins 1&2 of the RJ45 connector (RX) - it is not polarity sensitive.BPI-9460S this pin is direct Input +. This pin connects to the positive (+) output of the input bridge rectifier.
2
VA2
TX Input (2). This input pin is used in conjunction with VA1 and connects to the centre tap of the transformer connected to pins 3&6 of the RJ45 connector (TX) - it is not polarity sensitive.BPI-9460S this pin is direct Input -. This pin connects to the negative (-) output of the input bridge rectifier.
3
VB1
Direct Input (1). This input pin is used in conjunction with VB2 and connects to pin 4 & 5 of the RJ45 connector - it is not polarity sensitive.BPI-9460S this pin is direct Input +. This pin connects to the positive (+) output of the input bridge rectifier.
4
VB2
Direct Input (2). This input pin is used in conjunction with VB1 and connects to pin 7 & 8 of the RJ45 connector - it is not polarity sensitive.BPI-9460S this pin is direct Input -. This pin connects to the negative (-) output of the input bridge rectifier
5
-VDC
DC Return. This pin is the return path for the +VDC output.
6
+VDC
DC Output. This pin provides the regulated output from the DC/DC converter.
7
ADJ
Output Adjust. The output voltage can be adjusted from is nominal value, by connecting an external resistor from this pin to either the +VDC pin or the -VDC pin.
DC Electrical Characteristics
Note
1: Typical figures are at 25°C with a nominal 48V supply and are for design aid only. Not Guaranteed
2: The output ripple and noise can be reduced with an external filter, see application note.
3: Continuous short circuit duration is applicable at 25'C ambient temperature in free air. At higher temperatures or with restricted airflow (e.g. in a sealed enclosure) the duration will need to be limited to avoid overheating.
RT9460S Typical Connection Diagram
Reducing the output voltage, connect R2 between ADJ and +VDC
R2 Value
output voltage
R2 Value
output voltage
BPI-9460-3.3V
open
3.3V
0R
2.8V
BPI-9460-5V
open
5V
0R
4.4V
BPI-9460-12V
open
12V
0R
9.9V
BPI-9460-24V
open
24V
30K
18.2V
Increasing the output voltage, connect R1 between ADJ and -VDC
R1 Value
output voltage
R1 Value
output voltage
BPI-9460-3.3V
open
3.3V
0R
3.7V
BPI-9460-5V
open
5V
0R
5.7V
BPI-9460-12V
open
12V
0R
12.8V
BPI-9460-24V
open
24V
0R
25.5V
Reliability MTBF
About the life time ,we design according to the following:
1)life time of RT9460 : 100,000 hours @ 25°C
Safety test items & test report
Test Requested
Test result
Electric strength -1500Vrms at 50 to 60Hz for 60s, applied as specified in subclasuse 5.2.2 of IEC 60950
Pass
Mechanical / Environmental Performance data
Item
Requirement and Standard
Resistance to Wave Soldering Heat
max Preheat Temp range & time 120 ℃ / 180S,max soldering temp &time:265 ℃ / 4S
2
Solder ability
Solder able area shall have minimum of 95% solder coverage.And then into solder bath,Temperature at 245 ±5 ℃ , for 4-5sec.
3
Hand Soldering Temperature Resistance
T > =350 ℃ , 3sec at least.
4
Thermal Shock
subject to follow condition for 5 cycles.1 cycles:-55 ℃ , 30 minutes;+85 ℃ , 30 minutes
5
Humidity(Temp Cycling)
less than 95% (non-condensing) ( -20 to 70 ℃)
6
Temperature Life
temperature life at 85℃ for 96 hours.
7
Salt Spray
connectors to 5% salt-solution concentration, 35 ℃ ,Gold flash for 8 hours there will be no change in the gold layer
