Description
The BPI-9460 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard.
The BPI-9460 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 15W power to the port. The RT9460 provides a Class 0 signature.The DC/DC converter operates over a wide input voltage range and provides a regulated output. The DC/DC converter also has built-in short-circuit output protection.
Applications
- IP Cameras
- Wireless access point
- Security and alarm systems
- VOIP telephone
Features
- IEEE802.3af compliant
- Low output ripple and noise
- Short-circuit protection
- Adjustable Output
- Rohs compliantnt
BPI-9460 Product Selector
| Part Number |
Nominal Output Voltage |
Output current |
Maximum Output Power* |
Marking |
Package
| BPI-9460S-3.3V |
3.3V |
2A |
10W** |
3.3V |
SIL
| BPI-9460S -5V |
5V |
2.4A |
13W** |
5V |
SIL
| BPI-9460S -12V |
12V |
1A |
13W** |
12V |
SIL
| BPI-9460S -24V |
24V |
0.5A |
13W** |
24V |
SIL
- At 25°C with VIN = 48V
- Maximum Output Power: means it not could be operated in continuous stage .only short-term of Boot up/Heavy loading
Absolute Maximum Ratings
Parameter |
Symbol |
Min |
Max |
Units
| 1 |
DC Supply Voltage |
VCC |
-0.3 |
60 |
V
| 2 |
DC Supply Voltage Surge for 1ms |
VSURGE |
-0.6 |
80 |
V
| 3 |
Storage Temperature |
TS |
-40 |
100 |
OC
Parameter |
Symbol |
Min |
Typ |
Max |
Units
| 1 |
Input Supply Voltage1 |
VIN |
36 |
48 |
57 |
V
| 2 |
Under Voltage Lockout |
VLOCK |
30 |
36 |
V
| 3 |
Operating Temperature2 |
TOP |
-20 |
25 |
70 |
Ta / OC
