BPI-7604 IEEE 802.3af PoE Splitter module
[hide]Description
BPI-7604 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard. BPI-7604 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 15W power to the port. BPI-7604 provides a Class 0 signature. BPI-7604 DC/DC converter operates over a wide input voltage range and provides a regulated output. The DC/DC converter also has built-in short-circuit output protection.
Application
- IP Cameras
- Wireless access point
- Security and alarm systems
- VOIP telephone
Main sprc
- IEEE802.3af compliant
- Integrated LAN Filters
- Regulated 12V DC output
- Low output ripple and noise
- Wide Input voltage range
- Overload and short-circuit protection
- 1500V isolation (input to output)
- Simple installation
- CE and FCC part 15 certified
- Enables PoE functionality for legacy products
Connector and Pin Description
J1 | AUX IN 1.25mm | J3 | DC Putout 2 2.0mm |
1 | Ethernet cable spare pair 7,8 | 1 | 12V Output + |
2 | Ethernet cable spare pair 4,5 | 2 | 12V Output - |
3 | DC Auxiliary input 12V- | ||
4 | DC Auxiliary input 12V+ |
|J2 || POE_IN 1.25mm|| J4 ||NET out 1.25mm |- |1 LED- Internal connection J3|| 1 ||12V Output - |- |2 LED+ Internal connection J3 ||2 || 12V Output + |- |3 Ethernet cable 6 ||3 ||LED- Internal connection J1 |- |4 Ethernet cable 3 ||4 ||LED+ Internal connection J1 |- |5 Ethernet cable 2 ||5 ||Ethernet cable 1 |- |6 Ethernet cable 1 || 6 ||Ethernet cable 2 |- | ||7 ||Ethernet cable 3 |- | ||8 ||Ethernet cable 6 |}
