Banana Pi BPI-M2 Pro
Revision as of 08:32, 15 December 2021 by Sinovoip (talk | contribs)
BPI-M2 Pro Introduction
File:A BPI-M2 PRO.jpg
  • Mali-G31 GPU
  • 2GB LPDDR4
  • 16GB eMMC flash
  • 2 USB 3.0
  • RTL8821CU WiFi&BT 4.2 onboard
  • 1 GbE ethernet
  • HDMI output
Getting Started with BPI-M2Pro
Hardware inerface
HardWare Specification of Banana pi BPI-M2 Pro
Memory 2 GB LPDDR4
Wifi&BT Dual-band 802.11 b/g/n/ac WiFi 5 1×1 and Bluetooth 4.2 via Realtek RTL8821CU
USB ports 2x USB 3.0 host ports, 1x micro USB OTG port
Power Source 5 volt @3A via DC port
Size & Weight 65mm×65mm, 58g
OS Android and Linux
IR Yes Yes Yes N/A
BPI-M2 Pro 40PIN GPIO (CON2)
CON1-P02 VCC5V
CON1-P03 GPIOX_17 I2C_M2_SDA
CON1-P04 VCC5V
CON1-P05 GPIOX_18 I2C_M2_SCL
CON1-P07 GPIOX_5 SDIO_CMD
CON1-P08 GPIOX_12 UART_A_TX
CON1-P10 GPIOX_13 UART_A_RX
CON1-P11 GPIOX_3 SDIO_D3
CON1-P12 GPIOAO_8 TDMB_SCLK
CON1-P13 GPIOX_4 SDIO_CLK
CON1-P15 GPIOX_7 PWM_F
CON1-P16 GPIOX_0 SDIO_D0
CON1-P18 GPIOX_1 SDIO_D1
CON1-P19 GPIOX_8 PCM_DIN
CON1-P21 GPIOX_9 PCM_DOUT
CON1-P22 GPIOX_2 SDIO_D2
CON1-P23 GPIOX_11 PCM_CLK
CON1-P24 GPIOX_10 PCM_SYNC
CON1-P26 GPIOX_16 PWM_E
CON1-P27 GPIOA_14 I2C_M3_SDA
CON1-P28 GPIOA_15 I2C_M3_SCL
CON1-P29 GPIOX_14 UART_A_CTS
CON1-P31 GPIOX_15 UART_A_RTS
CON1-P32 GPIOX_19 PWM_B
CON1-P33 GPIOX_6 PWM_A
CON1-P35 GPIOAO_7 TDMB_FS
CON1-P36 GPIOH_5 SPDIF_IN
CON1-P37 GPIOAO_7 I2S_MCLK
CON1-P40 GPIOAO_4 TDMB_DOUT
BPI-M2 Pro Debug UART(CON1)
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
same to BPI-M5 source code.
same to BPI-M5 images.
Note: M2Pro is onboard 2GB ram, it's not work well for android, suggest to buy m5.
CoreELEC on BPI-M2 Pro
easy to buy sample : https://pt.aliexpress.com/item/1005002661831086.html?spm=a2g0o.store_pc_allProduct.8148356.1.4fd039a06wVleh
