Banana Pi BPI-R2 Pro
Revision as of 03:44, 26 August 2021 by Sinovoip (talk | contribs)
  • Mali-G52 1-Core-2EE
  • 2G LPDDR4 SDRAM (option 4G)
  • support 1 SATA interface
  • 1 CSI camera interface
File:BPI-R2 interface.png
Banana Pi R2 Pro
CPU Rockchip RK3568 Quad-core ARM Cortex-A55 CPU
GPU Mali-G52 1-Core-2EE
Storage Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port,SPI flash
Camera 1 CSI camera interfact
Video decoder(s) H.265 HEVC/MVC Main10 Profile [email protected] up to 4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps
Video encoder(s) H.264/AVC BP/MP/[email protected],up to 1920x1080@100fps, H.265/HEVC [email protected], up to 1920x1080@100fps (4096x4096@10fps with TILE)
Remote IR Receiver (x1)
LED Power Status and 8P8C
Power Source 5 volt @3A via DC Power and/or Micro USB (OTG)
