香蕉派 BPI-M5
Revision as of 09:19, 14 July 2021 by Sinovoip (talk | contribs) (→Linux)
BPI-M5介绍
Banana Pi BPI-M5
Amlogic S905X3 Processor
WiFi&BT扩展板, 802.11 a/b/g/n/ac 2T2R WiFi和蓝牙Bluectooch 5.0
  • Mali-G31 GPU图形处理器
  • 4GB LPDDR4内存
  • 16GB eMMC 板载存储.
  • 4 USB 3.0 端口
  • 1 GbE 千兆网口
  • HDMI 输出
开发快速上手
硬件接口
香蕉派BPI-M5 硬件规格表
Memory 4 GB LPDDR4
USB ports USB 3.0 PORT (x4)
Size & Weight 92x60mm, 48g
OS Android and Linux
Wifi无线 & 蓝牙BT扩展板支持
SDIO标准接口 wifi&BT5.0扩展板
  • WiFi&BT board, 802.11 a/b/g/n/ac 2T2R WiFi and Bluectooch 5.0 支持 BPI-M5 和 BPI-F2P
File:Wifibt module .jpeg
标准 USB interface Wifi&BT
  • Banana Pi Wifi&BT 4.2 USB wifi配件, 采用标准USB 接口, 除了支持香蕉派板,其他像树莓派等有USB接口的板也全部支持.标准IEEE 802.11b/g/n/ac(1T1R) USB WLANAnd BT Module
香蕉派BPI-M2 Pro ,BPI-M5 与 Odroid C4 和 Raspberry Pi 4硬件规格比较表
香蕉派 BPI-M2 Pro 香蕉派 BPI-M5 Odroid C4 树莓派 4
IR Yes Yes Yes N/A
GPIO PIN 定义
BPI-M5 40PIN GPIO 定义 (CON2)
CON1-P02 VCC5V
CON1-P03 GPIOX_17 I2C_M2_SDA
CON1-P04 VCC5V
CON1-P05 GPIOX_18 I2C_M2_SCL
CON1-P07 GPIOX_5 SDIO_CMD
CON1-P08 GPIOX_12 UART_A_TX
CON1-P10 GPIOX_13 UART_A_RX
CON1-P11 GPIOX_3 SDIO_D3
CON1-P12 GPIOAO_8 TDMB_SCLK
CON1-P13 GPIOX_4 SDIO_CLK
CON1-P15 GPIOX_7 PWM_F
CON1-P16 GPIOX_0 SDIO_D0
CON1-P18 GPIOX_1 SDIO_D1
CON1-P19 GPIOX_8 PCM_DIN
CON1-P21 GPIOX_9 PCM_DOUT
CON1-P22 GPIOX_2 SDIO_D2
CON1-P23 GPIOX_11 PCM_CLK
CON1-P24 GPIOX_10 PCM_SYNC
CON1-P26 GPIOX_16 PWM_E
CON1-P27 GPIOA_14 I2C_M3_SDA
CON1-P28 GPIOA_15 I2C_M3_SCL
CON1-P29 GPIOX_14 UART_A_CTS
CON1-P31 GPIOX_15 UART_A_RTS
CON1-P32 GPIOX_19 PWM_B
CON1-P33 GPIOX_6 PWM_A
CON1-P35 GPIOAO_7 TDMB_FS
CON1-P36 GPIOH_5 SPDIF_IN
CON1-P37 GPIOAO_7 I2S_MCLK
CON1-P40 GPIOAO_4 TDMB_DOUT
BPI-M5调试串口定义 UART(CON1)
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
开发资料
软件源代码
Android系统
Linux系统
documents
系统镜像
How to flash Android Image
  • 2020-12-11 release, Android 9.0 with kernel 4.9.113
Download: 2020-12-11-bpi-m5-android-9-emmc.zip
MD5: 962325face002250ad4254f7c4625f30
How to flash Linux Image
  • 2020-12-10 release, Ubuntu Mate Desktop 18.04 with kernel 4.9.236
Download: 2020-12-10-ubuntu-18.04-mate-desktop-bpi-m5-aarch64-sd-emmc.img.zip
MD5: 28e4f4e130949fa8257297303fc81139
  • 2020-12-10 release, Ubuntu Mate Desktop 20.04 with kernel 4.9.236
Download: 2020-12-10-ubuntu-20.04-mate-desktop-bpi-m5-aarch64-sd-emmc.img.zip
MD5: f95d69985e19f5c04179b3986e7bab10
  • 2020-12-10 release, Ubuntu Server 20.04 with kernel 4.9.236
Download: 2020-12-10-ubuntu-20.04-server-bpi-m5-aarch64-sd-emmc.img.zip
MD5: d918ebb98ae0d6ff00096193bd6bb059
  • 2020-12-10 release, Debian Buster with kernel 4.9.236
Download: 2020-12-10-debian-10-buster-bpi-m5-aarch64-sd-emmc.img.zip
MD5: 483b31ef3f64b3794b2ec204c1d9da95
Armbian unstable build for Bananapi M5 and M2Pro
Google Download: https://drive.google.com/drive/folders/1Cx_DA90Tbr8_M_8eQd-NwFUOp3UTwhYt
Baidu Cloud : https://pan.baidu.com/s/15y4LNg4K-w0vrwMTcg5VGQ Pincode: j9aj
CoreELEC
HuaWei OpenEuler
BPI-M5 github: https://github.com/BPI-SINOVOIP/BPI-M5-bsp
Discuss on fourm : http://forum.banana-pi.org/t/bpi-m5-run-huawei-openeuler-open-source-linux-system/12073
