Banana Pi BPI-R64
MTK MT7622
- 1G DDR3 SDRAM
- MTK7615 4x4ac wifi (option)
- support 1 SATA interface
- (1) USB 3.0
- POE function support
Read more for development :Getting Started with R64
Frank wiki : http://fw-web.de/dokuwiki/doku.php?id=en:bpi-r64:start
Hardware Revision
| HardWare Specification of Banana pi BPI-R64 | |||
| SDRAM | 1 GB DDR3 | ||
| SATA | support 1 SATA interface | ||
| On board Network | 5 10/100/1000Mbps Ethernet | ||
| Wifi | built-in 4x4n 802.11n (800Mbps) sysem-on-chip and MTK7615 4x4ac wifi Module (1733Mbps) (option) | ||
| USB | 1 USB 3.0 host | ||
| Buttons | Reset button | ||
| IR | PIN define with GPIO | ||
| DC Power | 12V/2A with DC in | ||
| Weight | 100g | ||
PoE support
more PoE module spec
4G support
- Error creating thumbnail: Unable to save thumbnail to destination
BPI-R64 GPIO Pin define
- Banana Pi BPI-R64 (MT7622) openwrt (Kernel 4.19) : https://github.com/BPI-SINOVOIP/BPI-R64-openwrt
- BPI-R64 Linux BSP(kernel 5.4):https://github.com/BPI-SINOVOIP/BPI-R64-bsp-5.4
- frank github(kernel 5.4): https://github.com/frank-w/BPI-R2-4.14/tree/5.4-r64-dsa
- OpenWRT: https://github.com/openwrt/openwrt/tree/master/target/linux/mediatek/mt7622
- BPI-R64 schematic diagram
- google https://drive.google.com/file/d/1QzKmIwgSNbCIXQbqLsTUELJCEPik3VGr/view?usp=sharing
- baidu cloud link: https://pan.baidu.com/s/18MEJpr5OTYmySZoyk3bO5Q pincode: amqt
- BPI-R64 DXF file for case deign : https://drive.google.com/file/d/1_YNsdQ9Cv7FVOGrqd6GP0Tu5u2cjLwTA/view?usp=sharing
- BPI-R64 DXF file and the parts used for the assembly datasheet: https://drive.google.com/file/d/1LK5HkP4AfE8xNLJMRHvc7JgexfkDBUAF/view?usp=sharing
- 3D printed case for Banana PI R-64. Link https://www.thingiverse.com/thing:4261948
- BPI-R64 3D design file update with SolidWorks :http://forum.banana-pi.org/t/bpi-r64-3d-design-file-with-solidworks/10910
- MTK MT7622A_Datasheet_for_BananaPi_Only : https://drive.google.com/file/d/1DVEv3bovA8cPti3Ln7d9lDBjMCGFSE5m/view?usp=sharing
- MT7622 Reference Manual for Develope Board(BPi) : https://drive.google.com/file/d/1cW8KQmmVpwDGmBd48KNQes9CRn7FEgBb/view?usp=sharing
- Banana Pi BPI-R64 debian Linux boot demo and bootlog:http://forum.banana-pi.org/t/banana-pi-bpi-r64-debian-linux-boot-demo-and-bootlog/8155
- Banana Pi BPI-R64 passed AWS Greengrass : https://devices.amazonaws.com/detail/a3G0h000000OvObEAK/Banana-Pi-R64
- Bpi-r64 quick start (boot from eMMC):http://forum.banana-pi.org/t/bpi-r64-quick-start-boot-from-emmc/9809
- Banana Pi BPI-R64 CE,FCC,RoHS Certification : http://forum.banana-pi.org/t/banana-pi-bpi-r64-open-source-router-board-ce-fcc-rohs-certification/10094
- Patchwork/Mailinglist there was a DSA-driver for mt7531 released : https://patchwork.kernel.org/project/linux-mediatek/list/?submitter=189635
Amazon AWS Greengrass
Release
OpenWRT & LEDE
- BPI-R64 new image : LEDE17 (OpenWRT) image Kernel:4.4.177 2020-04-09
- google driver : https://drive.google.com/drive/folders/1EK6fkGivZB3OmY38W8gN4rFAsnInMlNl
- baidu cloud : https://pan.baidu.com/s/1UR-Uli2chQ5tO9VCl5Yz6A Pincode:j00s
- Boot media: SD Card & eMMC ,two image
- MD5: 21a6d89979d473cde59f7d61f3
- discuss on forum: http://forum.banana-pi.org/t/bpi-r64-new-image-lede17-openwrt-image-kernel-4-4-177-2020-04-09/10924
- Mainline OpenWRT image
- 2020-05-08 updae ,Ubuntu 18.04 with kernel 5.4.0
- Fetures Map:
- Google Drive : https://drive.google.com/open?id=1zrOSS2QJPirSwoK5yJFx10SiOtxRjXPt
- 2020-12-22 Ubuntu 18.04 with kernel 5.4.0
- download link : https://download.banana-pi.dev/d/3ebbfa04265d4dddb81b/files/?p=%2FImages%2FBPI-R64%2FUbuntu18.04%2F2020-12-20-ubuntu-18.04.3-bpi-r64-5.4-sd-emmc.img.zip
- supports 4G Module(EC20)
- 2020-05-08 updae ,Debian10 with kernel 5.4.0
- Fetures Map:
AArch64 Linux
- Fetures Map:
- easy to buy sample: BPI official Aliexpress shop
