香蕉派 BPI-R2
Revision as of 09:55, 8 March 2021 by Sinovoip (talk | contribs)
BPI-R2概要
香蕉派 BPI-R2 with MT7623N
香蕉派 BPI-R64 with MT7622
香蕉派 BPI-W2 with Realtek RTK1296 chip design
BPI-R2 smart router design
BPI-R2 with acrylic case
BPI-R2集成MTK7623N 四核 ARM Cortex-A7 MP 支持主频1.3 ghz,BPI-R2 路由器提供丰富各种外设接口,包括 HDMI TX 高清接口, MIPI DSI 屏接口, PCIe2.0 接口, USB2.0 OTG 端口, USB3.0 端口, SATA 端口,5 千兆网口, 板载802.11a/b/g/n wifi 无线& BT4.1蓝牙 , 并且通过mini PCI-e支持 802.11ac/n WLAN
BPI-R2 系统支持 Android5.1,并完善支持 OpenWRT,Debian linux,Ubuntu linux, Raspbian 和其他嵌入式操作系统. 尺寸与BPI-R1完全一样大小, 支持 1080P y高清视频输入,40 PIN GPIO 与 Raspberry Pi 3一致.
  • Mali 450 MP4 GPU
  • 2G DDR3 SDRAM
  • Mini PCIE interface.
  • support 2 SATA interface
开始使用
硬件接口示意
Banana Pi BPI-R2 硬件规格
GPU Mali 450 MP4 GPU
Memory 2G DDR3 SDRAM
Audio Output(s) HDMI & I2S
Remote IR Receiver (x1)
LED Power Status and 8P8C
我们开发了 MT7615 802.11 ac wifi 模组 ,能方便的在 BPI-R2
BPI-R2 GPIO 定义
Banana pi BPI-R2 40 PIN GPIO 定义:
CON1-P02 VCC-5V
CON1-P03 I2C\_SDA0 GPIO75
CON1-P04 VCC-5V
CON1-P05 I2C\_SCL0 GPIO76
CON1-P07 PWM-003 GPIO206
CON1-P08 UTXD1 GPIO80
CON1-P10 URXD0 GPIO81
CON1-P11 URXD1 GPIO80
CON1-P12 I2S0\_BCK GPIO74
CON1-P13 UTXD0 GPIO79
CON1-P15 PWM-002 GPIO205
CON1-P16 URTS1 GPIO25
CON1-P18 UCTS1 GPIO24
CON1-P19 SPI0\_MO GPIO56
CON1-P21 SPI0\_MI GPIO55
CON1-P22 PCM\_CLK GPIO18
CON1-P23 SPI0\_CK GPIO54
CON1-P24 SPI0\_CSN GPIO53
CON1-P26 PCM\_RX GPIO20
CON1-P27 I2C\_SDA1 GPIO57
CON1-P28 I2C\_SCL1 GPIO58
CON1-P29 PCM\_RST GPIO22
CON1-P31 SPDIF\_OUT GPIO200
CON1-P32 PCM\_TX GPIO21
CON1-P33 I2S0\_MCLK GPIO126
CON1-P35 I2S0\_LRCK GPIO73
CON1-P36 PCM\_SYNC GPIO19
CON1-P37 SPDIF\_IN1 GPIO202
MIPI DSI \(屏显示接口\)
MIPI DSI of Banana pi BPI-R2
CN6-P01 VCC-3V3
CN6-P02 VCC-5V
CN6-P03 VCC-3V3
CN6-P04 VCC-5V
CN6-P05 GND
CN6-P06 VCC-5V
CN6-P07 GND
CN6-P08 VCC-5V
CN6-P09 NC
CN6-P10 GND
CN6-P11 NC
CN6-P12 DSI-D0N
CN6-P13 NC
CN6-P14 DSI-D0P
CN6-P15 DSI\_TE GPIO84
CN6-P16 GND
CN6-P17 I2C\_SDA2 GPIO77
CN6-P18 DSI-D1N
CN6-P19 I2C\_SCL2 GPIO78
CN6-P20 DSI-D1P
CN6-P21 CTP-INT GPIO23
CN6-P22 GND
CN6-P23 CTP-RST GPIO236
CN6-P24 DSI-CKN
CN6-P25 GND
CN6-P26 DSI-CKP
CN6-P27 GPIO28
CN6-P28 GND
CN6-P29 GPIO83
CN6-P30 DSI-D2N
CN6-P31 GPIO204
CN6-P32 DSI-D2P
CN6-P33 GND
CN6-P34 GND
CN6-P35 LCM\_BLPWM GPIO203
CN6-P36 DSI-D3N
CN6-P37 GND
CN6-P38 DSI-D3P
CN6-P39 NC
CN6-P40 GND
UART 串口定义:
CON2 P03 UTXD2
CON2P02 URXD2
CON2P01 GND
资源
软件源代码
参考文当
[链接: https://pan.baidu.com/s/1BCzYjVKeJz23ha2xwP-Stg 提取码: kwzt MTK 7623N datasheet for development board programming guide V1.1]
CE,FCC,RoHS
软件镜像
Ubuntu with kernel 4.4
Ubuntu with kernel 4.14
OpenWrt(LEDE)
  • Official OpenWR 18.06.4 for Banana Pi BPI-R2 image released 2019-7-04
image download:https://downloads.openwrt.org/releases/18.06.4/targets/mediatek/mt7623/
https://openwrt.org/toh/sinovoip/sinovoip_banana_pi_r2
Forum pthread:http://forum.banana-pi.org/t/official-openwr-18-06-4-for-banana-pi-bpi-r2-image-released-2019-7-04/9459
  • BananaPI BPI-R2 Openwrt18.06 Image Release and source code 2019-03-06
source code on Github: https://github.com/BPI-SINOVOIP/BPI-R2-OPENWRT-18.06
image download: https://dev.banana-pi.org.cn/Image/BPI-R2/Openwrt/1806/
MD5SUM
mtk-bpi-r2-EMMC.img : 5d1537c45679de352dd25d8dda46b9ad
mtk-bpi-r2-SD.img :71fce303abdceed4f1c3548d5a3fc207
forum Pthread: http://forum.banana-pi.org/t/bananapi-bpi-r2-openwrt18-06-demo-image-release-2019-03-06/8562
OpenMPTCProuter
  • Armbian preview image for Bananapi R2 / K4.19.y
https://www.armbian.com/bananapi-r2/
Centos 7
  • 2019-8-12 update.[BPI-R2] debian 10 buster image with Kernel 4.19.62, shared by frank-w
Kernel: 4.19.62,uboot 2019-07 with erase-env + sata-support,new preloader (2019-07-22),configured to ip 192.168.0.11 on lan0,openssh-server running with root-login (should be disabled afterwards),username/password: root/bananapi
google drive:https://drive.google.com/open?id=1oP7jy1KrrIOifvImo2nQ59wx3_9hHkgk
how to : https://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:storage#short_install-guide
forum discuss:http://forum.banana-pi.org/t/bpi-r2-debian-buster-image-with-kernel-4-19-62/9601
  • Image Release
  • Image Release
release date :2018-06-17
  • SD-Card images:
  • Discuss on forum :
yocto Linux
MQLinux 19.02 beta
  • update 2019-03-12,
Main features:
Highly streamlined embedded design system, running in memory
Mutilple Language (en/zh_CN currently)
DNS Proxy/Cache
DDNS
VLAN Extension for WAN
Multiple WAN (each ethernet port can be defined)
DHCP Server
FTP Server
PPPoE Server
Samber Server
VPN client/Server (PPTP VPN, IPsecVPN, OpenVPN)
Cloud Login
Firewall
IP-MAC Locking
Port Mapping/DMZ/UPnP
Diagnose Tools …
image dwonload: https://drive.google.com/file/d/1Ws2IUiCGSKKQ2dCM5XJBV-pog-hk17PM/view?usp=sharing
MD5: 09b58f050166ed5d09803e1de56d7890
Forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-r2-new-image-mqlinux-19-02-beta/8832
BPI-R2 相关项目
