Getting Started with BPI-QCar
About BPI-QCar
BPI Q-Car with micro:bit
BPI Q-Car with BPI-Bit
BPI-QCar with BPI-AI board
  • support Micro:bit, PBI:bit(Web:bit) and BPI-AI(WEB:AI) boards
  • support Makecode graphical programming(with micro:bit),support Webduino graphical programming(with BPI:bit),and it also support MicroPython arduino(Micro:bit/BPI:bit)
  • Compact body, strong integrity
  • N20 Miniature reducer
  • Infrared emission, infrared reception, line patrol, speed measurement, atmosphere lamp, I2C interface (support 3.3V and 5V), ultrasonic interface, buzzer, steering gear interface, needle row expansion port, expansion screw hole, etc...Fully functional, strong expansibility
  • Easy to use it.
Motor control
Ambient light control
Ultrasonic sensor control
How to use buzzer
Arduino code link:https://github.com/BPI-STEAM/Q-Car/tree/master/SoftWare/Web_Bit_Arduino/Buzzer_Demo
IR control
Objective: To master the infrared remote control of Q-CAR
Program effect display: infrared remote control Q-CAR forward and backward and turn
Arduino code link:https://github.com/BPI-STEAM/Q-Car/tree/master/SoftWare/Web_Bit_Arduino/IR_Control_Demo
Ultrasonic obstacle avoidance
Program effect display: boot the car forward, ultrasonic detection of the front distance, if the distance is less than 8cm, the car left and right to check the obstacles on both sides, choose the direction of the farther distance to turn, to avoid obstacles.
Arduino code link:https://github.com/BPI-STEAM/Q-Car/tree/master/SoftWare/Web_Bit_Arduino/Avoidance_Demo
巡线行驶
BPI-QCar with BPI:Bit use MicroPython
MakeCode编程点亮Micro:Bit
新建一个项目,参照下图的例程连接MakeCode积木,例如其中第一个积木块“show leds”可以在“Basic”选项栏目中找到,此积木可以自行编辑想要输出的图形
MakeCode编程环境有自带模拟程序运行效果的仿真器可以实时查看效果,通常显示在左上方
MakeCode编程环境也支持从外部导入项目文件,如经过MakeCode编译生成的.hex文件
注意:正确的.hex文件导入方式是将上文链接中的.hex文件下载到本地然后将其导入到MakeCode中,而不是直接将此链接导入,外部项目链接导入MakeCode的方式与此处不同
项目文件下载到本地后可导入MakeCode中查看和再编辑,也可直接通过USB烧录到Micro:Bit中直接运行
按钮控制Micro:Bit-基础
学习目标:使用Micro:Bit上的AB两个按钮控制LED矩阵所要输出的图形
在章节“使用MakeCode编程点亮Micro:Bit”的基础上,在MakeCode中“input”选项栏目中找到应用按钮控制的积木“on button A pressed”来进行编程
例程如下图,实现按一下A按钮显示英文字符“A”,按一下B按钮显示英文字符“B”,同时按下AB按钮后显示一个形似香蕉的图案
按钮控制Micro:Bit-进阶
学习目标:用MakeCode编程实现一个计数并显示的按钮控制程序
在前一章节的基础上,先在MakeCode中“Variables”选项栏目中新建一个变量名为“A_was_pressed_times”的变量,此时将在“Variables”选项栏目产生多个关于变量的积木
将“Math”选项栏目中的加法积木与“Variables”选项栏目中的积木镶嵌组合,参照下图例程
此时,我们就实现了在MakeCode编程并做出了一个利用加法计数的程序,按一次按钮A计数加1同时将计数值输出到LED矩阵中,按一次按钮B计数归0并清除LED矩阵的显示
车轮测速
学习目标:用MakeCode编程实现读取Q-Car上用于车轮测速的红外对管的高低电平信号并用计数法算出车轮转速
例程如下图,将程序烧录进Micro:Bit,将Micro:Bit与Q-Car连接,此时旋转Q-Car左右轮,可以从USB串口中读取到左右轮转速
电机控制
学习目标:用MakeCode编程实现Q-Car左右电机正反转控制
例程如下图,将程序烧录进Micro:Bit,将Micro:Bit与Q-Car连接,左右电机将同时正转2s,同时反转2s,右电机单独正转2s,左电机单独正转2s
氛围灯控制
学习目标:用MakeCode编程实现对Q-Car上10颗WS2812B彩色氛围灯的控制
例程如下图,将程序烧录进Micro:Bit,将Micro:Bit与Q-Car连接,Q-Car上的10颗WS2812B彩灯将同时以1800ms一周期循环彩虹光效
超声波传感器控制
学习目标:用MakeCode编程实现对Q-Car上HC-SR04超声波扩展模块的控制
例程如下图,将程序烧录进Micro:Bit,将Micro:Bit与Q-Car连接,将HC-SR04超声波扩展模块与Q-Car连接,将5V电源与Q-Car连接
可以从Micro:Bit的USB串口读取到超声波传感器检测到的距离以及Micro:Bit上的温度传感器数据,例程实现了对超声波传感器的温度校准
蜂鸣器的使用
学习目标:用MakeCode编程编写一段曲子并在Q-Car的蜂鸣器上播放
例程如下图,将程序烧录进Micro:Bit,将Micro:Bit与Q-Car连接,Q-Car上的蜂鸣器将循环两次播放曲子
