BPI-AI
BPI-AI(also name Web:AI for Webduino) design with K210 RISC-V chip design.An integrated artificial intelligence SOC chip solution that can accommodate neural network models, using a new risc-v instruction set for the field of artificial intelligence and edge computing. The main target market is the AIoT and STEAM education market,it support screen and camera. so easy to do many AI application, cowork with Webduino team. and support Webduino blockly for STEAM education.
Type Applications
- AI for Edge Computing
- Smart Building
- Medical equipment
- Automation & Process Control
- Robot
- IoT applications
- STEAM education
- 64-bit RISC-V CPU Dual-Core, up to 400MHz
- IMAFDC (RV64GC) ISA extension
- Hardware FPU (Float Point Unit), Double Precision
- 32 KB I-Cache per core and 32 KB D-Cache per core
- 8MB On-Chip SRAM 128Kbit One-Time Programmable Memory (OTP) ,Read Only Memory (ROM)
- DMA
- Camera and screen interface
- WiFI (ESP8285)
- JTAG, OpenOCD support
About Kendryte K210 chip
The Kendryte K210 is located in the SoC of the AI and IoT markets and is a very convenient MCU.
BPI-AI hardware
Hardware Interface
| HardWare Specification of Banana pi BPI-AI (WEB:AI) | |||
| CPU | Kendryte K210 64-bit RISC-V CPU Dual-Core, up to 400MHz,with neural processing unit (NPU) | ||
| Memory | SPI flash and The accelerator has its own memory, with 6MB of static RAM given over to the dual-core CPU and a further 2MB for the NPU coprocessor. | ||
| camera | 5 million pixel cameras | ||
| WIFI | ESP8285 wifi module support 802.11.b/g/n | ||
| Audio Output(s) | Built-in MEMS microphone supports 3W speaker output | ||
| LCD Screen | 8bit MCU 2.3 LCD,DPI 320x240 | ||
| Socket | Compatible with BPI: BIT Goldfinger,TF card ,Speaker,lithium battery interface | ||
| Development environment | Arduino IDE, MaixPy IDE ,Webduino | ||
| Switches | Reset, A/B key | ||
| Power Source | 5volt@2A via Micro USB ,lithium battery interface(3.7-4.2V) | ||
| Size & Weight | 51.6mm×67mm, 58g | ||
BPI-AI software
Source code on github
- K210 chip datasheet(English):https://drive.google.com/file/d/1AavU-bCoyA2BWSDB3NQBp41A7CvdJvBL/view?usp=sharing
- K210 chip datasheet(Chinese):https://drive.google.com/file/d/1_xQ3waq4ENHIlfJ7ujrfRSAClNAk6beL/view?usp=sharing
- K210 SDK(drive)、documents、compiler、OpenOCD Debugging software :https://kendryte.com/downloads/
- jacklab K210 wiki page : http://wiki.jackslab.org/K210
Support
- if you want to order or do OEM&ODM please contact : [email protected]
