Banana Pi BPI-M2 Pro
Revision as of 02:27, 1 February 2021 by Sinovoip (talk | contribs) (BPI-M2 Pro Introduction)
Amlogic S905X3 Processor
BPI-M5 case design
BPI-M2 Pro same size as BPI-M2+ , and interface is also same .so can use BPI-M2+ case.
  • Mali-G31 GPU
  • 2GB LPDDR4
  • 16GB eMMC flash
  • 2 USB 3.0
  • 1 GbE ethernet
  • HDMI output
Hardware inerface
HardWare Specification of Banana pi BPI-M2 Pro
Memory 2 GB LPDDR4
Network 10/100/1000 Mbit/s Ethernet ,WiFi&BT 5.0
USB ports USB 3.0 PORT (x2)
Size & Weight 65mm×65mm, 58g
OS Android and Linux
IR Yes Yes Yes N/A
BPI-M2 Pro 40PIN GPIO (CON2)
CON1-P02 VCC5V
CON1-P03 GPIOX_17 I2C_M2_SDA
CON1-P04 VCC5V
CON1-P05 GPIOX_18 I2C_M2_SCL
CON1-P07 GPIOX_5 SDIO_CMD
CON1-P08 GPIOX_12 UART_A_TX
CON1-P10 GPIOX_13 UART_A_RX
CON1-P11 GPIOX_3 SDIO_D3
CON1-P12 GPIOAO_8 TDMB_SCLK
CON1-P13 GPIOX_4 SDIO_CLK
CON1-P15 GPIOX_7 PWM_F
CON1-P16 GPIOX_0 SDIO_D0
CON1-P18 GPIOX_1 SDIO_D1
CON1-P19 GPIOX_8 PCM_DIN
CON1-P21 GPIOX_9 PCM_DOUT
CON1-P22 GPIOX_2 SDIO_D2
CON1-P23 GPIOX_11 PCM_CLK
CON1-P24 GPIOX_10 PCM_SYNC
CON1-P26 GPIOX_16 PWM_E
CON1-P27 GPIOA_14 I2C_M3_SDA
CON1-P28 GPIOA_15 I2C_M3_SCL
CON1-P29 GPIOX_14 UART_A_CTS
CON1-P31 GPIOX_15 UART_A_RTS
CON1-P32 GPIOX_19 PWM_B
CON1-P33 GPIOX_6 PWM_A
CON1-P35 GPIOAO_7 TDMB_FS
CON1-P36 GPIOH_5 SPDIF_IN
CON1-P37 GPIOAO_7 I2S_MCLK
CON1-P40 GPIOAO_4 TDMB_DOUT
BPI-M2 Pro Debug UART(CON1)
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
Linux BSP source code
How to flash Android Image
  • 2021-01-20 release, Android 9.0 with kernel 4.9.113
Download: 2021-01-20-bpi-m5-android-9-emmc.zip
MD5: 329cb877377bc9654ec7183764c5aa40
How to flash Linux Image
  • 2021-01-21 release, Ubuntu Mate Desktop 20.04 with kernel 4.9.236
Download: 2021-01-21-ubuntu-20.04-mate-desktop-bpi-m5-aarch64-sd-emmc.img.zip
MD5: ce6a8356775c9418d3807c5309eb33bd
  • 2021-01-21 release, Ubuntu Server 20.04 with kernel 4.9.236
Download: 2021-01-21-ubuntu-20.04-server-bpi-m5-aarch64-sd-emmc.img.zip
MD5: cc816d71237db473f9ef734dc39d37ac
  • 2021-01-21 release, Debian Buster with kernel 4.9.236
Download: 2021-01-21-debian-10-buster-bpi-m5-aarch64-sd-emmc.img.zip
MD5: f59f24eb02f345a2afb3033472f68d5e
CoreELEC
