Banana Pi BPI-M5
BPI-M5 Introduction
Banana Pi BPI-M5
Amlogic S905X3 Processor
BPI-M5 case design
Key Features=
  • Mali-G31 GPU
  • 4GB LPDDR4
  • 16GB eMMC flash
  • 4 USB 3.0
  • 1 GbE ethernet
  • HDMI output
Hardware inerface
Memory 4 GB LPDDR4
USB ports USB 3.0 PORT (x4)
Size & Weight 92x60mm, 48g
OS Android and Linux
BPI-M5 VS Odroid C4 VS Raspberry Pi 4
BPI-M5 VS Odroid C4 VS RPI 4
Banana Pi BPI-M5 Odroid C4 Raspberry Pi 4
Processor Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz Broadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
GPU Mali-G31 MP2 GPU Mali-G31 MP2 GPU Broadcom VideoCore VI
RAM 4GB LPDDR4 DDR4 4GiB with 32-bit bus width 2GB, 4GB or 8GB LPDDR4-3200 SDRAM
Storage micro SD card slot & 16GB eMMC flash on board micro SD card slot , eMMC connector for option micro SD card slot, non EMMC
Network GbE ,Optional WiFi USB dongle GbE GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE
Video Output 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) 2 × micro-HDMI 2.0
Audio Output 3.5mm jack and 1 x HDMI digital output Optional SPDIF optical output 3.5 mm analogue audio-video jack
DSI N/A N/A 2-lane MIPI DSI display port
CSI N/A N/A 2-lane MIPI CSI camera port
USB USB 3.0 x 4 TYPE C USB 3.0 x 4, 1 x Micro USB 2.0 port (OTG) 2 USB 3.0 ports; 2 USB 2.0 ports;
Power 5 volt @3A via Micro USB (TYPE C) 1 x DC power jack (Outer diameter : 5.5mm, inner diameter : 2.1mm) 5V DC via USB-C connector (minimum 3A*)
IR Yes Yes N/A
GPIO 40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). 40 x GPIO pins 40-pin GPIO header, populated
Button Reset, user and U-boot N/A N/A
LED Power Status and Activity status Power Status and Activity status Power Status and Activity status
Dimensions & weight 85mm x 56mm, 48g 85mm x 56mm 59g 88 mm × 58 mm, 46 g
Linux Support Linux & Android Linux & Android Linux & Android
BPI-M5 40PIN GPIO (CON2)
CON1-P02 VCC5V
CON1-P03 GPIOX_17 I2C_M2_SDA
CON1-P04 VCC5V
CON1-P05 GPIOX_18 I2C_M2_SCL
CON1-P07 GPIOX_5 SDIO_CMD
CON1-P08 GPIOX_12 UART_A_TX
CON1-P10 GPIOX_13 UART_A_RX
CON1-P11 GPIOX_3 SDIO_D3
CON1-P12 GPIOAO_8 TDMB_SCLK
CON1-P13 GPIOX_4 SDIO_CLK
CON1-P15 GPIOX_7 PWM_F
CON1-P16 GPIOX_0 SDIO_D0
CON1-P18 GPIOX_1 SDIO_D1
CON1-P19 GPIOX_8 PCM_DIN
CON1-P21 GPIOX_9 PCM_DOUT
CON1-P22 GPIOX_2 SDIO_D2
CON1-P23 GPIOX_11 PCM_CLK
CON1-P24 GPIOX_10 PCM_SYNC
CON1-P26 GPIOX_16 PWM_E
CON1-P27 GPIOA_14 I2C_M3_SDA
CON1-P28 GPIOA_15 I2C_M3_SCL
CON1-P29 GPIOX_14 UART_A_CTS
CON1-P31 GPIOX_15 UART_A_RTS
CON1-P32 GPIOX_19 PWM_B
CON1-P33 GPIOX_6 PWM_A
CON1-P35 GPIOAO_7 TDMB_FS
CON1-P36 GPIOH_5 SPDIF_IN
CON1-P37 GPIOAO_7 I2S_MCLK
CON1-P40 GPIOAO_4 TDMB_DOUT
BPI-M5 Debug UART(CON1)
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
Linux BSP source code
Linux BSP code: https://github.com/BPI-SINOVOIP/BPI-M5-bsp
How to flash Android Image
  • 2020-12-11 release, Android 9.0 with kernel 4.9.113
Download: 2020-12-11-bpi-m5-android-9-emmc.zip
MD5: 962325face002250ad4254f7c4625f30
How to flash Linux Image
  • 2020-12-10 release, Ubuntu Mate Desktop 18.04 with kernel 4.9.236
Download: 2020-12-10-ubuntu-18.04-mate-desktop-bpi-m5-aarch64-sd-emmc.img.zip
MD5: 28e4f4e130949fa8257297303fc81139
  • 2020-12-10 release, Ubuntu Mate Desktop 20.04 with kernel 4.9.236
Download: 2020-12-10-ubuntu-20.04-mate-desktop-bpi-m5-aarch64-sd-emmc.img.zip
MD5: f95d69985e19f5c04179b3986e7bab10
  • 2020-12-10 release, Ubuntu Server 20.04 with kernel 4.9.236
Download: 2020-12-10-ubuntu-20.04-server-bpi-m5-aarch64-sd-emmc.img.zip
MD5: d918ebb98ae0d6ff00096193bd6bb059
  • 2020-12-10 release, Debian Buster with kernel 4.9.236
Download: 2020-12-10-debian-10-buster-bpi-m5-aarch64-sd-emmc.img.zip
MD5: 483b31ef3f64b3794b2ec204c1d9da95
CoreELEC
