Getting Started with M5/M2Pro
Banana Pi BPI-M5
Amlogic S905X3 Processor
  • Mali-G31 MP2 GPU @ 650Mhz
  • System Memory – 4GB LPDDR4
  • Weight – 48grams
2. Download the latest android image.
2. Make sure bootable EMMC is formatted from sector 0 if you want bootup from SDcard, and make sure bootable SDcard is formatted if you want bootup from EMMC(because uboot read bootscript file from mmc:1 first, which is SDcard dev, This is used for quickly SDcard bootup debug or flash image to EMMC while EMMC is bootable).
3. Install bpi-tools on your Linux PC. If you can't access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
 $ apt-get install pv
4. Download Linux latest Linux Image.
5. Default login: pi/bananapi or root/bananapi
Install Image to SDcard
2. Install bpi image with Etcher on Windows, Linux and MacOS.
Install Image to EMMC
4. Install with dd command, umount mmcblk0p1 and mmcblk0p2 partition if mounted automatically.
 $ sudo apt-get install pv
 $ sudo unzip -p xxx-bpi-m5-xxx.img.zip | pv | dd of=/dev/mmcblk1 bs=10M status=noxfer
Build Linux Source Code
2. Build the bsp source code
3. If you want build uboot and kernel separately, please download the u-boot the kernel only, get the toolchains and configuration from BPI-M5-bsp
 # Overlays to load
 # Example combinations:
 #   spi0 i2c0 i2c1 uart0
 #   hktft32
 #   hktft35
1. Build and install wiringPi
 $ cd amlogic-wiringPi
 $ chmod a+x build
 $ sudo ./build
 root@bananapi:~/amlogic-wiringPi# gpio readall
 +-----+-----+---------+------+---+--- M5 ---+---+------+---------+-----+-----+
 | I/O | wPi |   Name  | Mode | V | Physical | V | Mode |  Name   | wPi | I/O |
 |     |     |    3.3V |      |   |  1 || 2  |   |      | 5V      |     |     |
 | 493 |   8 |   SDA.2 | ALT1 | 1 |  3 || 4  |   |      | 5V      |     |     |
 | 494 |   9 |   SCL.2 | ALT1 | 1 |  5 || 6  |   |      | 0V      |     |     |
 | 481 |   7 |  IO.481 |   IN | 1 |  7 || 8  | 1 | ALT1 | TxD1    | 15  | 488 |
 |     |     |      0V |      |   |  9 || 10 | 1 | ALT1 | RxD1    | 16  | 489 |
 | 479 |   0 |  IO.479 |   IN | 1 | 11 || 12 | 1 | IN   | IO.504  | 1   | 504 |
 | 480 |   2 |  IO.480 |   IN | 1 | 13 || 14 |   |      | 0V      |     |     |
 | 483 |   3 |  IO.483 |   IN | 1 | 15 || 16 | 1 | IN   | IO.476  | 4   | 476 |
 |     |     |    3.3V |      |   | 17 || 18 | 1 | IN   | IO.477  | 5   | 477 |
 | 484 |  12 |    MOSI | ALT4 | 1 | 19 || 20 |   |      | 0V      |     |     |
 | 485 |  13 |    MISO | ALT4 | 1 | 21 || 22 | 1 | IN   | IO.478  | 6   | 478 |
 | 487 |  14 |    SLCK | ALT4 | 1 | 23 || 24 | 1 | OUT  | SS      | 10  | 486 |
 |     |     |      0V |      |   | 25 || 26 | 1 | IN   | IO.492  | 11  | 492 |
 | 474 |  30 |   SDA.3 |   IN | 1 | 27 || 28 | 1 | IN   | SCL.3   | 31  | 475 |
 | 490 |  21 |  IO.490 |   IN | 1 | 29 || 30 |   |      | 0V      |     |     |
 | 491 |  22 |  IO.491 |   IN | 1 | 31 || 32 | 0 | IN   | IO.495  | 26  | 495 |
 | 482 |  23 |  IO.482 |   IN | 0 | 33 || 34 |   |      | 0V      |     |     |
 | 503 |  24 |  IO.503 |   IN | 1 | 35 || 36 | 0 | IN   | IO.432  | 27  | 432 |
 | 505 |  25 |  IO.505 |   IN | 0 | 37 || 38 | 1 | ALT4 | IO.506  | 28  | 506 |
 |     |     |      0V |      |   | 39 || 40 | 0 | IN   | IO.500  | 29  | 500 |
+ -----+-----+---------+------+---+--- M5 ---+---+------+---------+-----+-----+
4. Extract this tool
 $ ls -l logo/
5. Copy the boot-logo.bmp.gz
 $ adb root
 $ adb remount
 $ adb reboot fastboot
 $ fastboot device
 1234567890      fastboot
 $ fastboot reboot
Boot Sequence
1. om load bootloader from SDcard (Linux log example)
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 Use GP1_pll as DSU clk.
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 board id: 1
 fw parse done
 PIEI prepare done
 fastboot data verify
 result: 255
 DDR4 probe
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 eMMC boot @ 0
 sw8 s
 board id: 1
 fw parse done
 PIEI prepare done
 00000000
 emmc switch 1 ok
 ddr saved addr:00016000
 00000000
Erase EMMC for SDcard Bootup
   remount succeeded
   1234567890	fastboot
   OKAY [  0.044s]
   finished. total time: 0.044s
   OKAY [  0.047s]
   finished. total time: 0.047s
   erasing 'bootloader'...
   OKAY [  0.059s]
   finished. total time: 0.059s
   erasing 'bootloader-boot0'...
   OKAY [  0.036s]
   finished. total time: 0.036s
   erasing 'bootloader-boot1'...
   OKAY [  0.035s]
   finished. total time: 0.035s
   bananapi_m5_v1#amlmmc erase 1
   start = 0,end = 57343
   start = 221184,end = 30535679
   start = 0,end = 8191
   bananapi_m5_v1#reset
   resetting ...
d). Using uboot reboot command to restart from SDcard once time, Android in EMMC still exist completely, connect a debug console cable and press ESC while power on to enter uboot command line. After bootup from SDcard Linux, you can format the whole EMMC by dd command or flash the Linux image directly to EMMC.
   bananapi_m5_v1#
   bananapi_m5_v1#reboot sdboot
   reboot mode: sdboot
   reboot dev: sd
   before value = 0!
   after value = 4f5244c0!
   resetting ...
   bl2_stage_init 0x01
   board id: 1
e). The simplest way is insert the SDcard with Linux image flashed before power on, the Android bootloader will check boot.ini file whether exist in SDcard vfat partition, so that the SDcard Linux will bootup. After bootup, you can format the whole EMMC by dd command or flash the Linux image directly to EMMC.
   BPI: try boot from sdcard
   reading boot.ini
   reading Image.gz
   reading uInitrd
   reading overlays/i2c0.dtbo
   reading overlays/spi0.dtbo
   reading overlays/uart1.dtbo
   bananapi_m5# mmc erase 0 1000
3. Another situation is bootloader or uboot is corrupt, Rom load it from EMMC but hangup in u-boot or BL2, such as dram init failed, the boot process will hangup in BL2 of EMMC. The only way is format the EMMC with usb burning tool, or download the Android image completely and then try other ways to erase EMMC or flash Linux image to EMMC.
Wifi/BT support
1. Android test and support.
 rtl8723bu wifi/bt
2. Linux test and support.
 rtl8188eu wifi
 rtl8192eu wifi
 rtl8723bu wifi/bt
 rtl8811au wifi
 rtl8812au wifi
 rtl8812bu wifi
Coreelec
1. Get the source code.
More info refer to Coreelec official website and github
