Banana Pi BPI-CM4IO
BPI-CM4IO Introduction
![](/images/thumb/1/12/BananaPi_BPI-CM4_base_board_1.jpg/300x300x300px-BananaPi_BPI-CM4_base_board_1.jpg.pagespeed.ic.6sGSfHusyK.jpg)
Banana Pi BPI-CM4 with Amlogic A311D design
BananaPi BPI-CM4IO board is design for BPI-CM4 or RPi-CM4
- support MIPI DSI Display interface
- support MIPI CSI Camera interface
- Minipcie
- HDMI output
- 26 PIN GPIO
- USB TypeC OTG
- TF Card slot
- SIM Card Slot
- RJ45(1 Gigabyte Ethernet)
- USB 2.0 *2
- UART Debug Interface
- AD Key
- Size:100x72mm
BPI-CM4 Module PIN Out define
26 PIN GPIO of Banana pi BPI-CM4IO | |||
CON2-P01 | VCC-3V3 | ||
CON2-P02 | DCIN | ||
CON2-P03 | I2C1_SDA | GPIOX-17 | |
CON2-P04 | DCIN | ||
CON2-P05 | I2C1_SCL | GPIOX-18 | |
CON2-P06 | GND | ||
CON2-P07 | SPDIF_IN | GPIOH_5 | |
CON2-P08 | UART_B_TX | GPIOX-6 | |
CON2-P09 | GND | ||
CON2-P10 | UART_B_RX | GPIOX-7 | |
CON2-P11 | GPIOAO-10 | ||
CON2-P12 | I2SB_SCLK | GPIOA-1 | |
CON2-P13 | SPDIF_OUT | GPIOH-4 | |
CON2-P14 | GND | ||
CON2-P15 | IR-IN | GPIOAO-5 | |
CON2-P16 | I2S_MCLK | GPIOA-0 | |
CON2-P17 | VCC-3V3 | ||
CON2-P18 | I2SB_LRCLK | GPIOA-2 | |
CON2-P19 | SPI_A-MOSI | GPIOX-8 | |
CON2-P20 | GND | ||
CON2-P21 | SPI_A-MISO | GPIOX-9 | |
CON2-P22 | I2SC_DOUT_DIN_3 | GPIOA-7 | |
CON2-P23 | SPI_A-SCK | GPIOX-11 | |
CON2-P24 | SPI_A-SS0 | GPIOX-10 | |
CON2-P25 | GND | ||
CON2-P26 | I2SC_DOUT_DIN_0 | GPIOA-3 |
Uart PIN define of Banana pi BPI-M4 | |||
CON1-P1 | GND | ||
CON1-P2 | UART0-RX | ||
CON1-P3 | UART0-TX |
- BPI-CM4 Base board Schematic:https://drive.google.com/file/d/1IErCKqfWdU7gL7kUod2-wlpG7uE9EiVZ/view?usp=sharing
- BPI-CM4 Base board DXF file: https://drive.google.com/file/d/1-K3ESgU63S4ynwwNbe0p3Ol1ajOsufQ8/view?usp=sharing
