Banana Pi BPI-S64 Core
Revision as of 19:44, 11 October 2018 by JackZengWiki (talk | contribs)
Banana Pi BPI-S64 core use Actions SOC S700 design. S700 chip with ARM Cortex-A53 Quad-Core CPU,Mali450 MP4 GPU. BPI-S64 core with 2G LPDDR3 and 8G eMMC flash onboard.
BPI-S64 core modules are small enough to fit all kinds of hardware.In addition,S64 core also provides I/O boards with GPIO ports, as well as USB, MicroUSB, CSI, DSI, HDMI, and MicroSD and other many interfaces.
- CPU: Actions SOC S700,ARM Cortex-A53 Quad-Core CPU
- GPU:Mali450 MP4 GPU ,OpenGL ES2.0/1.1 OpenVG 1.1 EGL 1.5
- 2GB LPDDR3
- 8GB eMMC flash onboard
- BPI-S64 core board.
- BPI-S64 core Kit with expansion development board
- BPI-S64 core board spec
HardWare Specification of Banana pi BPI-S64 core | |||
CPU | Actions SOC S700,ARM Cortex-A53 Quad-Core CPU,Mali450 MP4 GPU | ||
Memory | 2GB LPDDR3 | ||
Storage | 8GB eMMC | ||
interface | SODIMM-DDR3,204 PIN , all S700 GPIO support | ||
size | 67.5 x 30 mm |
- BPI-S64 core development kit spec
HardWare Specification of Banana pi BPI-S64 core kit | |||
GPU | Mali450 MP4 GPU ,OpenGL ES2.0/1.1 OpenVG 1.1 EGL 1.5 | ||
Power | 5V @ 2A via DC power | ||
Low-level peripherals | 26 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. | ||
Onboard Network | 1 x 10/100/1000Mbps Ethernet | ||
Wifi/Bluetooth | AP6212 WiFi and BT 4.0 | ||
On board Storage | MicroSD \(TF\) card; 8G eMMC;SIM card slot | ||
Display | HDMI \(Type A\) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP ;LVDS | ||
Video decoder/encode | support Real-time vide decode of most popular vide formats ,such as MPEG-4,H.264,H.265. support video encoder for baseline H.264 | ||
Audio | support two audio device HDMI and headphone, also support Audio In/Out with PIN define. support 1 MIC in | ||
HDMI Out/In | 1* HDMI 1.4 | ||
Audio outputs/Inputs | HDMI, I2S audio,Audio micro out | ||
4G | USB standard 4G LTE interface | ||
USB 2.0 | 1x USB 2.0 OTG, 1 x USB port | ||
Display | 1* Mini DP ,1* LVDS lcd, | ||
Camera | 1 x DVP camera interface ,1 x MIPI interface | ||
RTC battery | RTC battery power interface | ||
battery | 3.7V battery interface. | ||
Buttons | Reset button, Power button, ADC button | ||
Leds | Red, Green, Blue | ||
Other | IR reciever | ||
Sizes | |||
Power | DC 5V/2A | ||
Weight | 150g |
- Actions S700 datasheet : https://drive.google.com/file/d/1x1V_RP4tQzn9-BkS2L90Xgyqqz3MpLWV/view?usp=sharing
- Banana pi BPI-S64 core debian linux demo 1080P and 4K player : https://www.youtube.com/watch?v=v-6w9jJDQKY&feature=youtu.be
