Banana Pi BPI-M5
BPI-M5 Introduction
![](/images/thumb/a/a9/BPI-M2_Pro_2.jpg/300x225x300px-BPI-M2_Pro_2.jpg.pagespeed.ic.QwYAEL6-Jj.jpg)
Key Features=
- Mali-G31 GPU
- 4GB LPDDR4
- 16GB eMMC flash
- 4 USB 3.0
- 1 GbE ethernet
- HDMI output
Hardware inerface
Memory | 4 GB LPDDR4 | ||
OS | Android and Linux |
BPI-M5 40PIN GPIO (CON2)
CON1-P01 | VCC-3V3 | ||
CON1-P02 | VCC5V | ||
CON1-P04 | VCC5V | ||
CON1-P06 | GND | ||
CON1-P09 | GND | ||
CON1-P14 | GND | ||
CON1-P15 | GPIOX_7 PWM_F | ||
CON1-P17 | VCC-3V3 | ||
CON1-P20 | GND | ||
CON1-P25 | GND | ||
CON1-P30 | GND | ||
CON1-P33 | GPIOX_6 PWM_A | ||
CON1-P34 | GND | ||
CON1-P39 | GND | ||
BPI-M5 Debug UART(CON1)
CON2-P1 | GND |
CON2-P2 | UART0-RX |
CON2-P3 | UART0-TX |
Linux BSP source code
- 2021-01-20 release, Android 9.0 with kernel 4.9.113
- Download: 2021-01-20-bpi-m5-android-9-emmc.zip
- MD5: 329cb877377bc9654ec7183764c5aa40
- 2021-01-21 release, Ubuntu Mate Desktop 20.04 with kernel 4.9.236
- Download: 2021-01-21-ubuntu-20.04-mate-desktop-bpi-m5-aarch64-sd-emmc.img.zip
- MD5: ce6a8356775c9418d3807c5309eb33bd
- 2021-01-21 release, Ubuntu Server 20.04 with kernel 4.9.236
- Download: 2021-01-21-ubuntu-20.04-server-bpi-m5-aarch64-sd-emmc.img.zip
- MD5: cc816d71237db473f9ef734dc39d37ac
- 2021-01-21 release, Debian Buster with kernel 4.9.236
- Download: 2021-01-21-debian-10-buster-bpi-m5-aarch64-sd-emmc.img.zip
- MD5: f59f24eb02f345a2afb3033472f68d5e
CoreELEC
